Question about Zebra Z4Mplus Label Printer
Unable to reset the printer, even to reset the password
I´m giving suppor to a Zebra Z4M Plus printer, and I find that when I try to reset the printer to the default values, I´m requested to type the password, and I use the default one (1234 as the manual says) and it doesn´t work. And if I change any value to any setting, and I select to chance to DEFAULT OPTIONS, nothing happens, the display turns back to the main menu. What would this be all about?
  • 53 Answers
Re: Unable to reset the printer, even to reset the...
After you reset to default settings you need to save changes for it to take effect. there is also another password. 1234 will only take you to level 2 you need the level 3 password. this password can be found in the service manuals and some of the full manuals
Posted on Nov 21, 2007
0 characters
3 Points
I neeed to replace the feeder roller under the print head on a Zebra Z4M plus where can I order them
You need to find a local Zebra Authorised Repair Service agent, go to and look in your country.
Oct 01, 2009 | Zebra Z4M Printer
I need to know what the difference is between a Z4m and a Z4m Plus.
Mechanically there isn't much difference. Electronically the 4Mplus replaced the 4M giving it more memory, ZPLII capabilities, and the ability to work with new barcodes and fonts that weren't supported by the 4M firmware.
May 14, 2009 | Zebra Z4M Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
The default password is 1234
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Z4m zebra printer problem
Might foul the ribbon sensor, clean the sensor and try to print again.
Mar 02, 2009 | Zebra Z6M Plus Thermal Label Printer
(zebra Z4M PLUS)
Here is a website to help with specs and supplies...
Nov 27, 2008 | Zebra Z4Mplus Label Printer
The printer is Z4M or Z4M plus? I found this error at z4m plus and the solution is to change the motherboard. Roberto Martinez Mexico
Nov 14, 2008 | Zebra Z4M Printer
My Zebra z4m plus
in the setup menu there is an option to choose what the machine does on powerup and head close. Yours is probably set to calibrate. Just change that setting to "none". Same thing with the pausing. there is a setting to pause after printing each label. Just change that option.
Nov 02, 2008 | Zebra Z4M Printer
Zebra z4m plus printer has no display showing
We had a computer tech change the CMOS battery inside the printer and the display starts to work again.
May 22, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
6,714 people viewed this question
Top Zebra Printers & Copiers Experts
Level 1 Expert
kenneth njonjo
Are you a Zebra Printer and Copier Expert? Answer questions, earn points and help others
