Turn your engine on with the A/C on high. Watch your cooling fans mounted behind the radiator to make sure they are running. If they're not running, you have something wrong in the electrical side of the fan system. The cooling fans are essential for cooling as they pull air through the radiator when the vehicle is not moving fast enough to cool the coolant. The problem probably lies in a relay, so replace the high speed fan relay with one you know works but is not essential for moment (rear window defrost or something similar) and put that in the relay spot for the high speed fans. If the fans kick on now, you need to replace your relay and this will probably also fix your overheating.
