Digix BT-100 Portable Bluetooth Wireless Speaker with Microphone BT-100 PURPLE Logo
A
Anonymous Posted on Sep 14, 2015
I have a "Digix BT-100 wireless Bluetooth speaker...Would like to know to use it (garage sale)
Website : www.digixmedia.com toll-free number=1-866-770-3688..... just want to know how to connect it to my I-pad or cell phone I-phone
2answers
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Digix BT-100 is not recognized by my Moto X android cell phone.
How do I set pairing mode
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
Wireless speaker does not turn off to end call
If the middle button is pressed and HELD for a few seconds, it should end the call. All android phones may not allow this function.
Device worked the first few times I used it, then lost volume and would not increase past first dot.
Please be sure to double check that the volume for BLUETOOTH on the device (phone, tablet, etc.) is also turned up. Please note that the volume buttons on the speaker may not always control the bluetooth volume via the device.
It pairs for a few seconds then quits
Has the speaker been paired with another device?
Is the device (phone, tablet, etc) paired with another bluetooth device that is within range?
If the answer is YES to either of the above questions this could be what is causing the problem. Please note that most devices (phones, tablets, etc.) can only connect to ONE bluetooth device at a time. Also note that the BT-100 speaker can only connect to ONE device at a time.
Digix BT-100 Portable Bluetooth Wireless Speaker says not connected when I try to pair it with my ipod.
Kathryn,
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired).
Hope this helps!
2answers
Battery light indicates its not charging
Back to the shop. Or look in the manual. Next time you better place a problem like this in the category audio, or speakers. It accedentely? is between Digital camera's.
Top Digix Video Cameras Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Digix Video Camera Expert? Answer questions, earn points and help others
