Question about Sharp R-1480 Microwave Oven
Frigidaire FMV156DCF has power but will not start. Light and fan will come on, but not clock and will not start.
My frigidaire model # ffmv164lsa microwave oven keypad does not seem to work. Some times it goes on by itself. Or if you unplug it 05 will go on. Cant set the clock. or if touch anything nothing happe
The answer you seek is to replace the keypad. Your unit is Stainless for you would have to replace the console as one piece part number 5304477377 I this helps. Good Luck
Apr 19, 2014 | Microwave Ovens
I need directions on how to set the clock. Can't find the manual
Select "User Pref" upper right corner of keypad, then select from menu "Clock" (item 5), then enter time, select "Start" - you are have just set the clock for Frigidaire FGMV174KFB
Nov 07, 2010 | Frigidaire FGMV174K Microwave Oven
The lights, fan clock etc. all are working, but it won't heat.
The door interlock switch is probably failed or out of adjustment. Beyond that the magnetron may have failed. Does the turntable etc all and light run while TRYING to heat? If so the magnetron or possibly the relay that sends power to the transformer or the rectifier may have failed. Note that about 5000 volts is sent to the magnetron so use great caution when working on this.
Jun 09, 2010 | Frigidaire GLMV168K Microwave Oven
GE spacemaker Power goes off and clock needs resetting
Try going to the breaker box and shutting off the power to the microwave for 10 minutes. After 10 minutes, turn back on and set the clock. This fixed my clock and turntable both. Apparently turning off the power resets the software in the clock.
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
We had sevseral boiling pots going underneath the over the range microwave without the exhaust fan on while also cooking in the microwave, we saw sparks in the microwave and it went dead. now nothing...
The main power fuse inside the MW may have been blown from the steam shorting out the circuitry. If so this fuse probably can be replaced. Lowes has replacement fuses.
Jun 13, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
We have a frigidaire microwave and in the middle of cooking, the motor stopped. The clock and cook time continued to work, but no heat. We've tried using at half power, on defrost, etc. but nothing seems...
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Mar 18, 2009 | Frigidaire Over-the-Range Microwave
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Sharp R-1480 Microwave Oven Logo
75 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
