Question about Frigidaire FRT15B3A Top Freezer Refrigerator
How does the rack come out of the freezer to adjust
The rack in the freezer is adjustable but I am not able to get the rack out of the side holes to move it
  • 89 Answers
There should be a plastic clip between the rack and left side of the freezer remove the clip then push the rack to the left real hard then the right side should come out raise the right side up and remove rack
Posted on Jul 12, 2009
Why is there no sign of a drain hole in my fridge part of the fridgfreezer
Check the position of the Fridge. It sounds like it is not level. Most fridges have adjustable height feet that will allow you to level the fridge. That may be your issue since the water cannot flow where it needs to. Put a stick level on top and adjust the feet until its level frnt to back and side to side.
Oct 16, 2016 | Refrigerators
Freezer door won't close tight
There should be adjustments in the hinge assembly. Go to Jen-Air .com, then select parts. They will have diagrams to view for repair, adjustment etc.
May 06, 2014 | Jenn-Air JCD2389G Side by Side...
Freezer rack
Without further info, this is just a guess; but generally 'Frig/ Freezer racks may be drop in, or slide in, or pinned. Does the fron or the back (or both) Lift? is Ice holding it in place. Some lift in the front & then slide out. Some lift in the back then you slide it sideways in the front and release one side, tilt it and slip the oter pin out of its hole. The ones that are adjustable usually have slotted bars in the back. You lift the front several inches and then pull it out of the slots in the back. Most of the time the door(s) must be fully open to get them out.
Mar 27, 2012 | Refrigerators
Refrigerator freezes food
Adjust the "freezer" knob. This adjustment adjust the amount of cold air coming from the freezer to the fridge.
Jul 02, 2010 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
My KSRS25ILBL03 side by side - the freezer has lots of frost, the bottom of the freezer if full of ice. I removed the ice (hairdryer), found the drain to the bottom pan frozen. Cleared that, & water...
main reason for lots and lots of frost is door seals not tight all round.look along the length of them to make sure and adjust by pulling/pushing into shape,also are the doors level???? would also cause doors not to be airtight.(adjusters/feet are under both outside corners).
Apr 17, 2010 | KitchenAid KSRG25FKSS Side by Side...
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
My ge refrigerator leaks water
During defrost cycle, the water produced is suppose to drain away through a small drain hole located behind the racks in the freezer section where you'll need to remove the rear panel to see the drain hole. This hole it very likely clogged.
Be careful to unplug the refrigerator before doing any work on it!
May 29, 2009 | Whirlpool GD2SHGX Refrigerator
How to adjust fridge and freezer doors on Kelvinator C520 Litre
how do you adjust the freezer door on a Maytag side by side 26 cu ft refrigerator?
Apr 04, 2009 | Refrigerators
Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Mar 23, 2009 | KitchenAid KSCS25FKSS Side by Side...
Adjusting headlights on 2003 honda accord
Further to Emmisionwiz's answer that worked for me - the holes are in the black plastic covering the radiator support, to each side more or less in line with the headlights. They are marked with an "A" and rotation directions for UP and DOWN. The Phillips screwdriver goes into the hole about 45 degrees from vertical and engages the adjusting rack, where the teeth of the Phillips screwdriver are the pinion. If you shine a flashlight down the hole you can see the rack teeth and all becomes clear. But you will need a long Phillips screwdriver and a little bit of luck.
In the owner's manual it says the lights are adjusted correctly at the dealership and if they need adjustment because of a trailer then take the car to a Honda certified mechanic.
I have a 2004 Accord also and the method is the same for that one too.
Aug 17, 2008 | 2003 Honda Accord
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
235 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
