Question about Olympus FE-210 Digital Camera
In shooting mode the lcd screen is black
The lcd screen is black when it is in shooting mode
Re: In shooting mode the lcd screen is black
Olympus says this is a bad image processing chip. They will replace it at no charge if you are still within the year warranty period. They require proof of purchase i.e. receipt, copy of charge card statement, copy of warranty card, etc. Contact them for further information on how to return it.
Posted on Apr 04, 2008
0 characters
3 Points
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Digital Cameras
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
Rear lcd screen black in shooting mode but works fine in playback
Solved the problem by going to the Canon product support site. It seems that there is no problem at all. The way the camera is designed is the problem. To be able to use the rear display lcd as a view finder, the camera needs to be able to lift the mirror to allow the sensors to pick up the image and display it on the screen. The 20D does not have this abilitiy. Apparently some later models do allow you to raise the mirror. It was this feature on those models that led me to believe that the 20D should do this too.
Jan 25, 2010 | Canon EOS-20D Body only Digital Camera
LCD screen is black in Photo mode Canon SD1100;
Press DISP. button, and repeat untill the display shows up
Aug 10, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
When shooting my screen is black and pics. are black
try to take video on Movie mode, if you won't get picture on LCD the CCD is dead. That means you need to replace the whole zoom lens. it costs a lot, not worth to repair.
Apr 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera screen remains black when I turn on shooting mode
Turn the camera on. With the screen showing, press the DISP button and this will give you a selection of different screen views i.e. squares for aligning shot squarely; black - thru viewfinder only; etc. Different modes will give you different screen displays i.e. P setting screens are different to when you have the camera set on AUTO.
Hope this helps.
Jan 11, 2009 | Canon PowerShot S51S Digital Camera
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Blank LCD Screen when in shoot mode
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 23, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Olympus FE-210 Digital Camera Logo
352 people viewed this question
Top Olympus Digital Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Digital Camera Expert? Answer questions, earn points and help others
