Question about Samsung HP-S4273 42 in. Plasma HDTV
Samsung TV shurts it self off and truns on and
Samsung TV shuts it self off and truns on and then off several times now it wont work. Why?
    Sergeant:
    Champion:
  • 249 Answers
Problem with the circuit within.
Posted on Jul 12, 2009
Samsung ln22a450 red light indicator blinking 5 times also sound like initial screen but no picture no audio after that. 10 min later the tv it shut off by it self
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 02, 2014 | Televison & Video
Samsung Savyy wont trun on. it blinks red
please use other samsung battery same as your phone if not the issue is on the phone it self.
Dec 20, 2013 | Cell Phones
I have 87 class motorhome with a ford 460 4bbl crab , we can drive it 5 min or 5 hrs but it will shurt off like if if u trun the key off,it will restart by trun the key off then restart it and it will go...
How old is the fuel pump?
Have you driven with a pressure gauge
tied to a wiper or taped to the windshield,
to watch fuel pressure when it quites
Sep 20, 2011 | 1987 Ford F 350
Our TV keeps shutting it self off intermittenly. Sometimes it will stay on for hours, other times it shuts itself off every few min then will run again for hours. We are selling the TV, but would like to...
My Samsung big screen showed the same symptoms. It ended up being two $5 resisters that burned out a very short time after purchase. My extended warranty took care of it but it took several service calls and the end solution was to replace the entire light engine.
Most of the time heat is the cause for shut down. Check the vents which allow air to circulate thru the set, also be sure the fan is working.
The first thing a repair man will do is replace the bulb. If you can do it yourself you can save some $$.
My advice is to find a good TV guy. One who's been around for a while. Sorry couldn't be more help. Good Luck!
Dec 30, 2010 | Televison & Video
Samsung 650 series fflat screen turn power on tv turns it self on and off many times by itself befor it stays on now it wont stay on only turns on and off
My research indicated that the problem is related to the power supply over heating. My wife suggested that we place our small 6" fan behind the tv. We did & the tv has not shut off for three days. Hope this works for you.
Marc & Alicia
Jun 12, 2010 | Samsung Televison & Video
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
Samsung SP50L6HD Tv turns it's self off. Time
sir it may happen if the auto off option is enabled and the timer is enabled........... check for this options if they r and enabled then disable that........... or give your tv to the service shop and check for any problems
Jul 20, 2009 | Samsung Televison & Video
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Samsung problems
You most likely need to change your lamp you can get lamps at http://www.samsungparts.com/
be sure to check your lamp to ensure you get the right one.
hope that helps.
Feb 14, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HP-S4273 42 in. Plasma HDTV Logo
100 people viewed this question
Henry  Thomas
Henry Thomas
