Yamaha 2007 Grizzly 450 Auto 4x4 Logo
R
Ronald Lorbiecki Posted on Sep 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It turns over but does not start. I feel I have tried everything but it won't start.
Steve P
Level 3:
  • Yamaha Master 3,912 Answers
  • Posted on Mar 10, 2016
Steve P
Yamaha Master
Level 3:
Answers
3912
Questions
5
Helped
1305704
Points
15904
Hey Ronald,
LOL.. tried everything huh.. nothing left to do but buy a new one.
If you would furnish me some (a lot) of information, everything you have done in detail, we'll get it fixed!!
1helpful
2answers
2012 grizzly 2wd won’t start unless I jump the solenoid switch I’ve replaced the solenoid switch and the ignition assemble still won’t start without jumping what else could it be?
Did you check the starter button. Look to see if it has power then check the wire going to the solenoid and see if it is sending power.
Aug 20, 2018 • ATVs
I have a noise and skipping feeling when coming right off idle it feels and sounds like the rear diff i changed rear diff new axles and bearings new u joints took trans apart and inspected its fine.
There's
this website www.reliable-store.com
They have books on ALL vehicles.
it covers wiring diagrams, electrical diagrams,
fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have 1987 toyota 4runner model and I keep servicing and when needed repair it on my own. worth it !!!
My 2014 Polaris Sportsman 850 XP started just fine in the cold this morning but when I went to start it again I turned the key and everything turns on but it doesn't start or fire it just cranks ove
check transmission shift levers.
polaris has over ride safety switches..
owners manual may help....
or fuel ice blockage at or near the tank pickup,or flow/noflow valve.
could be ice in float bowl of carb. (if not efi.)
...maybe use hair dryer to heat area near carb/efi unit.
2helpful
2answers
Polaris 500 efi atv c power won stay on keeps shutting off
you have a short circuit on a positive wire. inspect your fuse box and your wiring harness for any visual damage
Won,t start
spark @ plug ? gas to eng ? compression in eng? will run if you have all these. adjusted properly !!! what do you have or dont have ?
1helpful
My 250 Recon won't start.
need more details but it could be as simple as a low battery ,,,, try jump leads first
2007 polaris hawkeye won't start
If I try and pull start it and it just makes noises tried to jump start it and dose nothing what could it be I bought a new battery but no way of checking if it's charged or not
Jun 26, 2012 • Polaris ATV
Top Yamaha ATVs Experts
ADMIN Andrew
ADMIN Andrew
Arnie Burke
Arnie Burke
john h
Are you a Yamaha ATV Expert? Answer questions, earn points and help others
