Question about Singer Sewing Machines
Singer model #2263 Just stopped running, is not lopcked up, light still works.
  • 36 Answers
SOURCE: thread bunces up on the bottom causing machine to
I would start by looking for a problem with the bobbin tension. Do you have the bobbin threaded through the case correctly? Is the the bobbin tension set to loose? Another thing that can cause it to spool up on the bottom is if it sews a bunch of stitches all in the same spot or real close, do you have the presser foot tension to loose?
Posted on May 23, 2010
  • 36 Answers
SOURCE: How do I fix timimg on a singer 2263
There should be one or two set screws behind the bobbin shuttle, they could also be in the bobbin shuttle. You will loosen them st the timing and then retighten them. The Timing on a sewing machine is really straight forward, but that doesn't mean its not a pain in the but. When the needle is at the bottom of its travelthe hook on the shuttle should be coming around to meet the needle. As the needle starts back up it will create a loop in the thread for that hook to catch. Therefore the needle needs to start up before that hook is directlly in line with the needle. But the hook has to be above the eye of the neelde. So rotate it back and forth with no thread and watch to see when the hook passes the needle. It will probably take several attempts but you can do it. Do it in small movements. and only tighten the set screws enough to hold the shuttle in place to check it. Do not forget to retighten them.
Posted on May 27, 2010
hazelgrace
  • 340 Answers
SOURCE: where do i oil my 2263 singer simple machine
Hi
Try on the singer site.
http://www.singerco.com/accessories/manuals.html
Just type in 2263 and click on search.
Three options appear on the next page. The manual can be downloaded by clicking on free download!
There seem to be free oiling instructions available, also by clicking free download!
This should be just what you need!
Posted on Sep 22, 2010
Tally Girl
  • 1133 Answers
SOURCE: The machine will sew about three inches then the
You can download an instruction manual for Singer machines from here http://www.singerco.com/accessories/manuals.html, just type in the model number and click "search".
This sounds more like top thread is not in tension though so have you checked tension is working okay?
However, to adjust timing you will need a service manual or general instructions for a horizontal hook sewing machine. You may find a video that helps with this on You-tube, I just leave it to the experts.
Posted on May 23, 2011
  • 5381 Answers
SOURCE: Singer 2263 instruction manual does not show where
First make sure that the needle is fully up. Then you need to open the hinged front cover and unscrew the needle plate screws. Remove the bobbin. Brush out any lint now. Remove the bobbin case. Then snap the hook retaining arms outwards. Remove the hook cover and hook. Put no more than 2 drops of sewing machine oil on the the case (center right hand side). Then turn the hand wheel until the hook race is in the left position. Replace the hook and then the hook cover. Snap the hook retaining arms back into position. Replace the bobbin case and bobbin. Then replace the stitch plate.
Test the machine on a piece of waste fabric. If the hook keeps jamming, take the machine in for maintenance. The parts that may need to be replaced are the race or the shuttle hook. However without seeing the unit I do not know if there is not another problem. Some parts for the 2263 are available here: http://www.sewingpartsonline.com/singer-2263-sewing-machine-parts.aspx .
Singer has a second manual available with the oiling instructions for the 2263 here: http://www.singerco.com/uploads/download/1213_oiling-2263.pdf . See the diagrams on this page for where things line up. The rest of the instruction manual is also online here: http://www.singerco.com/uploads/download/1180_2263%28eng_spa_fre%29.pdf .
I hope this helps.
Posted on Oct 08, 2011
I need a repaire manual for a singer simple 2263 sewing machine
This site might have what you need. Repair manuals can be very hard to find. I don't know that all the links on this site are still good but it is one of the only places I've even seen repair manuals for Singer machines listed. Best of luck.
http://sewing-machines.blogspot.ca/2008/08/singer-online-manuals.html
Feb 17, 2015 | Singer 2263 Mechanical Sewing Machine
How to lubricate Singer Sewing Machine Model 2263
Oiling instructions--as well as the user's manual--is available as a free download on the Singer site under "Support and Resources."
Jul 23, 2014 | Singer 2263 Mechanical Sewing Machine
Singer 2263 instruction manual does not show where to lubricate or how to adjust the hook which keep jamming
I hope this helps.
Oct 08, 2011 | Singer 2263 Mechanical Sewing Machine
The machine will sew about three inches then the hook gets several threads around it and stops. I think the timing is off. How to set hook timing on a 2263 Singer Sewing Machine?
May 22, 2011 | Singer 2263 Mechanical Sewing Machine
Where do i oil my 2263 singer simple machine
Hi
Sep 22, 2010 | Singer Sewing Machines
Thread bunces up on the bottom causing machine to
May 23, 2010 | Singer 2263 Mechanical Sewing Machine
Sewing Machines Logo
225 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
