Question about Kenmore 47772/47774/47779 Electric Double Oven
Kenmore double oven
Oven P/N 91148385890 S/N 8Z6998230 has a code with F7 and keeps coming on even if oven is not being used. Please let me know what this mean and how to fix.
Thx Ron Reiling
  • 473 Answers
This is what f 7 means:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Will need to replace the oven control. Part # is WB36T10486 for black and WB36T10488 for white. Cost is $314.75 for black and $417.99 for white. You can get it at http://www3.sears.com/.
Posted on Nov 16, 2007
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
Ge profile performance double oven. getting an F7
F7 is a stuck keypad/button.
Push all buttons at random several times each. This will sometimes un-stick a stuck button.
If that does not work the keypad control will have to be replaced.
Jan 16, 2010 | GE Ovens
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F7 error in Kenmore double oven
You can find my solution to the most common cause of the F7 problem at the following link:
I have shared my fix with over two thousand unhappy GE customers. Most report success. I hope that it works for you too. Please let me know by sending an email to:
hutchipop@yahoo.com
Regards,
Powerman
Nov 20, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore double-oven (electric)
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Sep 22, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Oven is not working
No, the door is able to be opened, light works. No press switch works on the pannel and F 7 shows up on the scren along with time. I even can not fix or change the time. ANd, F7 goes away after pressing clear and comes back by itself after a while in both upper and lower. This is a Kenmore wall double oven. I do not know the model name, but it is not much used in teh last 5 years. Looks like a new one.
Jul 19, 2008 | Kenmore 47722 / 47724 / 47729 Electric...
Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore Elect Built-IN Oven Model 790
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
http://www.fixya.com./howto/h155060-dreaded_f7_error
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Feb 23, 2008 | Ovens
Double oven
ovenman, there's not a complete model number here but in the Kenmore line F7 is the code for a stuck function switch or bad keypad. Makes sense that it's telling you to start the lower oven. Try removing the ribbon cable from the board and cleaning the ends with an eraser. Reseat it and see if the code comes back. Make sure to kill the power before doing this. Catriver..post back.
Mar 28, 2007 | Kenmore 47732 / 47734 / 47739 Electric...
Kenmore 47772/47774/47779 Electric Double Oven Logo
178 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
