Control panel shows flow ok then power light comes on for about 10 second thens gose out still read salt, temp.voltage and ect. this is a Aqua Rite generator also check input voltage and 20 amp fuse
Off on swich on, voltage present , fuse on circuit board ok flow switch shows we have flow
Depending on the water temperature the actual salt level reading can be inaccurate.
If the water temp is below 65 the reading will sometimes show a lower salt level than the actual level.
Did you recalibrate the power center?
Have you tested the salt level independently?
I would first test the water or have it tested, many pool stores offer this service for free. It helps to have an accurate reading and not rely on salt test strips.
Once you know the actual salt level you can attemptrecalibrate the system and see what reading you get.
For an aqua rite system you flip the toggle to super chlor, to off and back to auto , wait 5-10 seconds you will hear a click then press the button next to the display , tI'll you see the salt level calibrating.
Hi, I believe you have an Aqua Rite Salt Chlorine Generator. Check system with no flow will always happen on start up but once flow is constant it will go away.
