Question about Electrical Supplies
Champion generator won't start and keep backfiring
    New Friend:
Use a cordless drill and a 3/8 drive Socket conversion that fits the center Bolt on the fly wheel and spin it the correct direction and it will fire up really easy.. just for anyone else that incounters the same issue in the job of at home..
Posted on Mar 11, 2019
    Sergeant:
  • Electrical S... Expert
  • 231 Answers
You need to rest the Valves. We have a guide here: https://www.generatorguru.com/need-help/
And videos on the Valves purchasing page to show you how to do this. Just look up your model to see the video: https://www.generatorguru.com/champion/
If you need any further help let us know and we would be happy to assist you.
Regards,
The Generator Guru Team
Champion generator won't start and keep backfiring - image-vhadt2dsdy2ffi30hpfrh3ev-1-0_2.jpg
Posted on Jun 11, 2018
    Top Expert:
  • 10,061 Answers
Tune up also check keyway under flywheel clean fuel system or valve sticking open
Posted on Jun 01, 2018
2 Suggested Answers
SOURCE:
  • 17 Answers
SOURCE: Tecumseh HM80 on coleman generator. won
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Posted on Mar 01, 2009
My Champion 4000 watt generator will not start in cold weather
If you want it to start with a start motor, driven from a battery, my guess is the battery is in bad condition. Normally a battery will perform less when temperature is going down, but an old or worn out battery can't perform at all when it is cold. I would check that first. Just take a good battery to start one of them and see what happens. Then see if you want to replace them.
Nov 22, 2014 | Champion 3500/4000 Watt Portable Generator
My champion generator 9000 watt breakers keep poping
How much time have the Generator?
looks like batteries needs to change it.
Aug 11, 2014 | UPG 12V 18Ah Champion Generator 9000 7000...
Guardian propane generator hard starting. At 20 F backfires and won`t start. Goes to overcrank.
It needs a cold weather option, one that heats the oil and also the carb so the LP gas does not freeze the carb. A common problem
Nov 04, 2013 | Guardian Electrical Supplies
I bought a champion generator 2 yrs ago.It ran when I bought it. Have not occasion to use it until now. It will not fire. It had some rust on the flywheel. Removed the rust. I replaced the spark plug.
Probably only one of these issues to cause that. gas not turned on or flooded- ck spark plug to see if it is wet, check to see if the spark plug is getting power by taking it out leaving the wire on it and holding it about a 1/8 of a inch away from some exposed metal part of the frame and have someone try to start it. if you get a spark then ck your gap and put it back. Ck your choke too to see if it is on. also if it was flooded then leave the choke off and keep trying to start it. if it was stored outside, it may have water in the gas.
Oct 27, 2012 | Champion 3500/4000 Watt Portable Generator
Champion generater. It seems fuel pump is not pumping the gas . what to do?
First start small Check to see if there is any clogs in the line also check the fuel filter if the pump is broken go to google and type the model number in and that should bring up everything about that and possibly help you find parts for it
Mar 10, 2011 | Champion International CPE 1000Watt...
The coil rope broke I would like to know how i can repair it. Generator 5500 watt champion.
If I understand correctly, you have a pull-start generator.
The rope to the pull-start broke.
This happened to us out on the job one day.
Our equipment might be different than yours. Our pull-start assembly is held with 4 bolts. Simply remover those bolts and lift off the cover ... carefully. The rope is attached to something I will call a pulley. The rope wraps around the pulley several times.
Do not lift out the pulley that the rope attaches to >> or the spring that re-winds the rope will come un-sprung (at least it did on our machine). If the spring comes unwound, then you got another job, and have to put the spring back also. Your machine might be different.
Keep pulley in place. Remove rope. Get another rope with same diameter and length and put it in.
Oct 18, 2010 | Champion International Champion Power...
Electrical Supplies Logo
2,177 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
