Question about HP Photosmart 4180 All-in-One Printer
I have this same problem since my purchase last september 08.
When my C4580 sits idle for a long period of time, it shuts off. I can only get it to work again if I unplug and replug. Then it works great.
    Habit-Forming:
  • 121 Answers
Do check if the printer is in sleep mode,if yes turn it off and restart you printer again.
Posted on Jul 13, 2009
Cranks no start or fire add gas down throat of carbs and it back fires out pipes and carbs
bikes that sit for long periods of time need there points or electronics pick-ups serviced , rust and aluminum corrosion happens over time on these
miss fires are sure signs of this to mean out of time
and yes the carbs/tank will need a total cleaning out too
Sep 17, 2015 | GAS Motorcycles
Why wont my transmission engage that i replaced?
The key may be in how long it has been sice you friend used it last.
If it sat up for an extended time period the seals could have dried/cracked due to no lubrication, there could be a varnish buildup in the valve body as well.
Just a guess on this.
If it did sit for a while, I would recommend adding Lucas transmission additive ( around 12-15 bucks the large bottle) to the trans and letting it sit and idle and run up and down for a while trying to soften the seals and cleaning varnish. It may take several hours. While in idle occasionally put the trans in reverse, neutral, drive, low 1,2 etc to have the selector ask all gears to move.
I don't normally promote brands but personal experience says that this stuff works....if there is a problem it can help with.
If this doesn't help I'm lost and it could be a trip to the trans shop. Hope not.
May 29, 2014 | 2003 GMC Sierra 2500HD
Snowblower c950 52361 throttle will not change out of idle
Sounds like snow blower has been sitting since last season. Remove carburetor shield and move throttle linkage at top of carburetor. They some times seize or tighten up from sitting.Spray with WD-40 or something to lubricate.
Feb 22, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Dryers stops after 30 seconds of running.
#5 post_old.gif September 24th, 2009, 08:49 AM jake.gif?dateline=1263924303 Jake user_offline.gif Appliance Tech - Admin Join Date: Aug 2004 Location: Springfield, Oregon Posts: 32,822 Thanks: 48 Thanked 1,244 Times in 1,238 Posts reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_highpos.gifreputation_highpos.gifreputation_highpos.gif icon1.gif So you need the motor control board #17 here?
http://c.searspartsdirect.com/lis_pn...2059-00001.png
Here's the motor control board for your model:
Manufacturer's Number: 8544799
Jun 30, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Vehicle idles high for a few minutes, then shuts
did u use fuel stabalizer? if not the gas can turn into a varsale like substance that can clog fuel filter and reck injector seal's, also check the disributor cap and rotor for condensation, this can happen over a period of sitting
Jun 07, 2010 | 1985 Toyota Pickup
Carrier model #58rav070-08 flashing error code #31
I would check the back of the unit to see if any debris has accumulated then check for the filter and make sure it is clean. Look at the front of the a/c where the filter sits and see if the coil behind the filter is dirty. If so the unit needes to be cleaned. This can be done by purchasing a can of coil cleaner at the hardware store and follow the directions to clean the coil. What the system is saying is there is a blockage somewhere causing this code. Not being serviced in 4 years would be the possible cause because of the amount of debris in the air over that 4 year period. Good luck on the repair hope this helped you.
Dave
Dec 08, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Last line not printing
I have HP C4599 and I spent an hour online with chat support. I guess my problem was some bidirectional thing. Check this link out to see if it helps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Apr 28, 2009 | HP Photosmart C4580 All-in-One InkJet...
Van has to sit overnight after long idle, in order to start.
See if the vents on your gas cap is clogged up. The gas cap could cause the fuel tank not to vent properly, causing fuel issues
Apr 26, 2009 | 1999 GMC Savana
Problem to turn on my RX65
Obviously you have pressed the power button on your RX65 in order to try to power it up since you mention that the green light on the SmartCord comes on. Here is one possible solution, which resolves any stored user settings which might have become corrupted due to power fluctuations:
First, press the power button so that the radar detector is turned off (green light is off). Then hold down the two buttons used for programming and, while holding these programming buttons down, press the power button. Release all three buttons once you see "RESET" displayed on the RX65's display. Your RX65 has now restored all factory default settings from a separate area of programmed memory, and this (hopefully) will restore your RX65 to proper operation.
Jan 12, 2009 | Pro RX65 Radar Detector
HP Photosmart 4180 All-in-One Printer Logo
83 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
