There is a condensate build up in my Trane XP 100 Air handler located in my hot Florida garage. The unit sweats on the out side and inside water drips through the heating unit which now shows rust marks and onto the squirrel cage fan. Condensate water is then splahed onto the fiberglass insulated walls of th air handler. Mold is beginning to build up both on the inside walls and on the fan unit. The air handler performs fine. My home is kept cool, but I am concerned about this condensate and the use of the heater which is used for about 2 weeks each winter. I have used a silicon seal around the sections of the air handler then covered this with duct tape. The bottom of the air handler is dry. The top of this unit is cold and wet. The garage is (Florida) wet and humid. I would put a styrafoam insulating board on the outside of the metal housing of the air handler but this should'nt be necessary or the trane company would have put heavier insulation whe they made the unit. What should I do to correct this problem? The unit is only 8 years old Lee Ganden leesme@comcast.net
  • leesme Jul 13, 2009
    I have done all these things. I even had my service contract company "recondition " the air handler.
    Of course they want to sell me a new air handler. The only thing I have not done is insulated the outside of the metal cabinet. Yes the coils were cleaned and the condensate line has been vacuumed. I do this every 4-6 months.I also use a mold remover when I do preventive maintenence.
    Also this the first of 4 emails that I received on my computer. I have not as yet read the others but in "'on line" contacting "fixya" I was disconnected twice and had to reenter my credit card number. I mentioned this online. I certainly hope you will help me resolve my problem and only charge me once.
  • 2,418 Answers
This is complicated, as you know condensation can not be avoided when cold air comes in contact with
hot humid air. Here is what I would try. You have to gain access to your evap coil. Which means tearing into the sheet metal cover. The updraft A coil sits in a plastic drain pan which is leaking or it is over full of condensation water, spilling down the inside wall due to fan/air press, it's not draining proper due to rust or dust/dirt/old crud that just gets in there. Hot humid air is mixing with the cold air in the area of your copper pipes and drain going into the evap. causing some condensation out side the box. Be sure that your suction line is insulated good also. You will need some good heavy sheet plastic, (if you have ever had a car door apart you have had to deal with a similar plastic there). You will have to glue this plastic on to the a coil in this area, it will give a wall of insulation between the coil and the metal wall cutting down on the amount of warn/cold air mix. Also gives a you a splash guard for water to run down into the drip pan. Now you have to clean the pan and most likely rebuild the area around the pvc drain pipe (most times it will be cracked in this area now due to age, & hot/cold/hot/cold - a good silicone or stuff called GOOP works fine to fix the drain and to glue the plastic cover in place. You will also need some rubberized cork or a good tar puddy. OK, get out your tools, get a jug of ice tea, turn that a/c off, get out there and get busy. No talking - put the call phone away, no sooner than you get into it, somebody will call and distract you making you wait another day.
Posted on Jul 13, 2009
  • 3,361 Answers
One. Take a shop vac and clean out the condensate drain line. It may be draining slowly causing water to lift from the drain and re-circulate. Two. Check for air leaks from any duct especially the return duct. Three. Remove the blower motor and clean the squirrel cage blades of mold,mildew and dust particles. Four. While Trane air handlers are sealed well they can still leak air. Seal all panels with hvac metal tape. Five. Go ahead and insulate the unit with styrofoam or ductboard. Six. If you have not had a evaporator coil cleaning done do that also.Eight years is a long time without a coil cleaning. No matter how well you maintain your filters lint and dust gets past them and lodge in the coil causing reduced airflow that causes increased condensation.
Posted on Jul 12, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
No suction pressure at condenser test port
i would suspect the valve on suction side not open. if the other system failed on a burn out you could have a blocked dryer or orfice at coil.
Apr 20, 2014 | Goodman CLQ36AR49 Air Conditioner
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
I have a Ruud 2 ton split system and the system will not cool. The compressor and fan on the outside unit works and the fan blower on the air handler works too. The temp on the lines coming into the...
The small line coming in from the outside unit should be warm to hot and the larger line should be cool and sweating with water forming on it. I am taking for granted that the unit was working if so it sounds as if the unit is low on freon. your inside coil should be sweating a lot from top to bottom if it is only cool or sweating on the bottom but less to nothing up top you are low on freon. When very low the unit will stop working just like a broken valve in the compressor. If it is just a little low it will not cool properly and at night it might even freeze the inside coil up.
Aug 08, 2010 | Ruud Handle Air Conditioner
I have water running from under the passenger side interior floor board what could it be coming from or has any one else experienced it really flows when turning corners
It sounds like condensed water from the air conditioner. Just like a glass with ice in it sweats, the cold part of an air conditioner sweats. That water needs to go somewhere. There is a drain on the bottom of the ductwork that comes out under the car, often toward the passenger side.
If the drain gets plugged, the A/C still sweats, but the water builds up inside the ductwork.
You can often clear the drain by blowing some air up the drain from the outside. (Don't use too much pressure!)
Jun 15, 2010 | 2000 Pontiac Grand Prix
Trane Air Conditioner air handler drips water
are you still having issues with your twg030a140b1? the heatpump that you own should not be having this issue the question is the configuration of the coil in the AHU is it properly installed. I am a distributor for Trane equipment and am wondering if the install tech installed correctly
May 30, 2010 | DeLonghi Trane 5t Rooftop Air Conditioner...
My domectic roof top air con is getting condensation on the plastic cover inside the van
Hi; Is the drain for the condensate draining. You will have to check the top unit to see if water is present. You can also check the air filter to see if it needs to be cleaned. Please only use a household cleaner and hot water on the filter screen. Also what is the inside temp. when You notice the sweating. If Your in a very humid climit some times the unit will sweat until it can remove excessive moisture from the inside space. Also does the tstat seem to be working normally and holding temp. ...alpharome416
Feb 22, 2010 | Dometic Rooftop RV Air Conditioner
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
Jan 15, 2010 | Omega Trane Furnace Draft Inducer Blower...
Trane Air Handler and Trane Thermostat with no power. Please help
First of all put back the jumper wire you remved Rc to Rh and also put the red wire to either one then the white to W, the green to G and the yellow to Y .That is for the thermostat wiring for a not heat pump outdoor unit.Remember this electronic thermostat has a time delay so the unit will take a few minutes to start.All this if the problem is the thermostat.But also when nothing works it could be that the drain line is clogh and some air handlers have a flood switch who shut the unit off if drain is clogh(it could be located in the drain line out of the air handler or inside it on the drain pan.) newer TRANE units have it inside.
Aug 13, 2009 | Heating & Cooling
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
