SOURCE: washer stops when handle released
unloader valve not functioning properly causes pressure overload and stalls engine
SOURCE: Hello there.My Karcher pressure washer motor
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
SOURCE: i have a k7.91 pressure washer the motor runs but stops or pulses
This sounds like a problem with the pressure sensor which is located on the water inlet side of the pump. This switches the power to the motor when there is sufficient inlet pressure and water flow. This pressure switch can get partially siezed up, and not operate correctly.
You will need to dismatle the unit and identify the pressure switch, dismantle it and lubricate it with silicone grease.
SOURCE: I have a C/H mod. PW1380- worked trouble free for
Bud The internal seals have blown just enough to cause this to malfunction, whilst it is only a small cost for the seals themselves the overall cost is $200 to repair as it has to be tested and servicd as a company policy ( just had my own done for the same reason)
It is not DIY as the tech showed me some of the pitfalls in self attempted fix and I am glad i didn't fiddle. The case is easily broken if you dont know how to open it and that;s just for starters.
Please rate my help++++Thanks for using FIXYA
SOURCE: Campbell Hausfeld PW1380 Pump won't run when water hose is connec
http://www.ppe-pressure-washer-parts.com/campbell-hausfeld-pw138000-pressure-washer-parts
Hope this helps. I have the same problem. It's not the switch but the mechanism that slides inside the switch, which activates the switch to go on and off. I fnally found it so hopefully they have the part in stock. It's not a clogged wand trust me I have torn it completley apart and found out it is the mechanism in the switch is plastic and breaks.
