I use the adhardware wizard it says that a problem occured and that i may not be able to use the device which is true. it just wont work. in the device management screen it shows that the drive is plugged in but has yellow circle with a black exclamation mark in it.
Have the drive driver available. In Device Manager, delete the drive. Power off your system. Check the hardware connections for the drive. Reboot your system. There should be a prompt for the drive. Install the driver. If there is no prompt for the drive, the cable or drive could be faulty. Hope that helps.
Try this Solution : Download a firmware flashing tool, and an Updated Binary File for the Drive, Then Run the Firmware Flashing tool, and Locate where the binary file you downloaded is, then click on Start.
The link for the Firmware Flahing tool and the Binary File for the drive is : http://www.allfirmware.narod.ru/OS.htm Its a russian site, but just scroll down and locate the model number of your Sony CD-RW, You'll see both the Firmware flashing tool as well as the Updated binary file for it just beside it. Hope this helps. Goodluck!
What is the power supply for the Norcent 5224pi-072 - I haven't had this connected since moving and...
(More)
What is the power supply for the Norcent 5224pi-072 - I haven't had this connected since moving and I had misplaced the Power adapter and found one that connects, but not sure its the correct one
i have a mad dog dvd burner but no program to burn dvds what is a good one. my main goal is to rip...
(More)
i have a mad dog dvd burner but no program to burn dvds what is a good one. my main goal is to rip dvds so i can put them on my ipod to watch while traveling
i have a insignia computer and has a sony dvd and cd-rw neither of them work modelsony cd-rw...
(More)
i have a insignia computer and has a sony dvd and cd-rw neither of them work modelsony cd-rw crx230ed and sony dvd-rom ddu1613 cant find driver please help me. Edison
i've uninstalled the drive then reinstalled it but after I use the adhardware wizard it says that a...
(More)
i've uninstalled the drive then reinstalled it but after I use the adhardware wizard it says that a problem occured and that i may not be able to use the device which is true. it just wont work. in the device management screen it shows that the drive is plugged in but has yellow circle with a black exclamation mark in it. i've downloaded drivers but each time i go to install them one says sony cd extreme is not installed properly and the other says no matched drives detected. please, what can i do???
Hey i just want to know what i can do because my system is not working on CDs whenever i insert the...
(More)
Hey i just want to know what i can do because my system is not working on CDs whenever i insert the cds reads error but the radio is working is there anything i can do to fix it? please help.
