Question about HP Officejet Pro L7680 All-In-One Printer
Images have lines down them when I print - HP Officejet Pro L7680 All-In-One Printer
    Sergeant:
    Champion:
  • 249 Answers
Reinstall cartriges.
Posted on Jul 12, 2009
Minolta di200f
Mam/sir
does this line appear if you put the original on the big glass and make a copy? If not then when you use the document feeder you do not use the big glass, you use the small glass check the small glass for dirt etc. and clean it. DO you print to this machine are prints OK? then narrows the field down. IF the line appears using the big glass check the image unit or the fuser the hot part can open the right door open the hot part Wait to let it cool down check that neither fuser roller has a scratch or line on it. for the image unit try to print and stop the machine by open the right door to try to catch the paper before it goes thru the hot part does you line appear if so image unit is bad .
Apr 18, 2012 | Minolta - DI200F Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
I just bought this printer and I have a newer HP Photosmart Plus all in one printer. Unfortunately, I cannot get either printer to print in mirror image. Can you tell me what I need to do to get at least...
Usually you use your software to flip the image before you send the file to the printer. Thus, what program are you using to create the fabric transfers?
This is easiest if you are dealing with an image. Find the command section for layouts and then choose flip or rotate horizontally. For example in Paint, the Rotate drop-down is part of the main ribbon below Crop and Resize. If you are trying to do a line of text, use a drawing program and write the line of text. Select it and then flip it. Write all of the lines of text and repeat the rotation for each one. Similarly do this for any images or lines of images.
When finished, print a test page on regular paper before using the fabric transfer paper.
(Publisher in Office or similar programs will also do this well.)
If you are using images from a file, import it into an appropriate software program to do the rotation then save it to a new file name before printing.
I hope this helps.
(some printers have the mirror image option in the Advanced Settings. Not many of the ones that I have used have the feature.)
Sep 15, 2011 | HP DeskJet 1000cxi InkJet Printer
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Line down the left side of the photocopies
If this only occurs with copies (not with printed jobs), then your problem is most likely dust/dirt on the scanner (not necessarily the glass), or on the optics that feed the image to the scanner. If it's on print jobs also, it could be a simple image drum problem (they wear out over time, and frequently manifest their impending failure with vertical lines appearing down printed/copied pages.
Aug 13, 2009 | Brother MFC-7440N Laser Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Image blurs as the page prints
It might be your printer catridge problem. Try changing it and giving it a nozzle clean.
Feb 06, 2009 | Lexmark X3350 All-In-One InkJet Printer
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Same lines won't print
Sorry, but this is impossible, as a "printer problem". This is clearly a "software/buffer/document" problem.
This can ONLY happen (on two printers, same results) if the DOCUMENT has "exclusive" properties or instruction sets, or "invalid data" for the "missing" lines. For example, you may be printing an HTML document with "DO NOT CACHE" meta tag or java instructions about specific lines or form entries. Many sites (like banks, registration, or encrypted mail/login pages) do this as a security measure to prevent critical data from being inadvertently printed (and ending up outside in trash cans for an ID thief to pilfer). Other possibilities: The lines are NOT text data, they might be IMAGES of text, and saved in a format the printer/buffer does not support. Any of these examples would allow the software to DISPLAY the specific (missing) lines of text -yet NOT print them.
To test my theory (almost a certainty really), simply open the document and select PRINT SCREEN key (or use whatever key commands capture the screen as an image). This copies what YOU see, to the clipboard as a single "image" file (instead of a variety of ASCII characters, images, and code).
Next, open "PAINT" in accessories under MSlop (or any IMAGE editor like Photoshop, Gimp, etc)
Select NEW and agree to the screen size you are using (1024x768, 800x600, 1280x800, etc)
Select PASTE from file menu (or CTRL/V keys). Your document will now appear.
Print the document. The "missing lines" will now show up! If the document is too long for one screen shot, you may have to scroll down, recapture (PRINT SCREEN, etc) and paste one or more images into each other before printing it as a single IMAGE.
Nov 18, 2007 | Canon PIXMA iP90 Mobile Printer
HP Officejet Pro L7680 All-In-One Printer Logo
71 people viewed this question
Seeker5211
Seeker5211
