Siemens Gigaset 8825 base station.
Use Siemens power supply C39280-Z4-C483
(printed on power supply)
Input:120V AC/60Hz/82mA/9.85VA
Output:9V AC/750mA
Type:FW 6299
Class 2 Transformer
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Was this helpful?
Yes
No
Popular Solutions for Siemens Gigaset 8825 Cordless
Phones rings ... base unit panel goes crazy ... remote phones go into search mode ... cannot answer...
(More)
Phones rings ... base unit panel goes crazy ... remote phones go into search mode ... cannot answer phone call
Is there anyway to set the system to record a message if you are already on the line and can't...
(More)
Is there anyway to set the system to record a message if you are already on the line and can't toggle over to the second-incoming call?
I dropped my Siemens Gigaset 8825 and now it has problems. Sometimes it shows ''time out errors''....
(More)
I dropped my Siemens Gigaset 8825 and now it has problems. Sometimes it shows ''time out errors''. The cordless phones all say ''searching''. Sometimes the ring sounds strange or there is no ringing sound for an incoming call. Sometimes when dialing out it won't accept or display all the digits.
hello, i can't seem to get the cordless phone that pairs w/the big phone to work! It says I need to...
(More)
hello, i can't seem to get the cordless phone that pairs w/the big phone to work! It says I need to register it, but it still doesn't work!!
