When moving the mixer tiped over in the trunk and oil leaked out. It is making a grinding sound at times when mixing thicker things. I need to know what kind of oil to use and where to put it. Thank you. Kathryn Price.
First off -- if it's still under warrantee, you'll want to go to
kitchenaid.com and find the nearest service center. The next thing I
say starts with "void the warrantee" steps. :)
It's very simple to open a stand mixer to see if you've got a simple problem or a bad one.
Unplug it.
Follow
the aluminum "Kitchen Aid" band to the back of the unit, there's one
main screw. Remove this, and set it aside with the band which should
come right off at this point.
Now, there should be two screws on
each side of the unit where the band used to be. Remove each of these.
They're all identical, so no worries if you mix them up.
Now you
can lift the top off of the unit and see inside. The motor is at the
back of the unit, the gear box at the front is where the oil is coming
from. Try (GENTLY) to tighten the screws that hold the gearbox
together. With a little luck, the gearbox screws had come loose and it
was oozing oil out through the seals. If they're all firm, then you've
got more serious problems and you'll want to find a service center for
it.
If the leak was just that the gearbox housing was loose, then you can open it up and see the grease that's inside. It's very thick grease, not liquid oil at normal temperatures, but I don't know what type of grease it actually is in yours.
The grinding sound you describe makes me think you've broken or dislodged the bearing chase though, and you've got bits of metal and/or small (1 - 2 mm diameter) bearings loose in the gearbox.
In my area small town in Costa Rica, I am the only one that does maintenance on kitchen aid mixers...
(More)
In my area small town in Costa Rica, I am the only one that does maintenance on kitchen aid mixers and there must be around 59 units of different years mostly KSM5 models but others a bit older Heavy Duty and some more. Need maintenance manual for this , how can I obtain same? Parts are available at the capital city Please advise on obtaining thr amnual or manuals.. Speed plates the same for all models?
We have Heavy Duty kitchen aid and will not pick up speed. Have changed brushes as they wear out to...
(More)
We have Heavy Duty kitchen aid and will not pick up speed. Have changed brushes as they wear out to fast. Rotor on brush end is worn out to a cone shape wear is more in end towards bearing. What do reccomend
