Question about Nokia Cell Phones
Nokia 6210 Classic: menu not working properly
I can't use the ''recent called menu''(don't know if that is the correct name). If I have an unanswered call, it says so on the screen, but when I want to see who called nothing happens. When entering the ''log-menu'' I can click on for example unanswered calls, but the menu stays the same, except for the top which now states that I'm in under unanswered calls. The only way to exit the menu, is by pressing the hangup-button.
My phone is a nokia C300.how can i delete the kontakts in the last used list?
the steps below work on most nokia phones.. here:
1. menu
2. go to call log/logs
3. search for "message recipients"
4. delete the contact name you want
5. that contact name will no longer be on the "recently used"
How to delete quot recently used quot contacts
Jul 06, 2016 | Nokia C300
359322020615824 plese reset security code NOKIA 6500 classic
Go to the following link and you will be directly connected to nokia secret codes site.
http://gleez.com/articles/did-you-know/nokia-secret-codes
please don't forget to rate our answers properly.
Oct 29, 2011 | Nokia 6500 Classic Cellular Phone
My nokia 6303c phone ask for restriction code when i insert sim
Hi my name is ELIKE Can u unlock my nokia6303c FOR ME PLEASE. I don't know what is the restriction code. This is the IMEI is 359333/03/881321/0 .this is my email address elikofi2000@yahoo.com@yahoo.com please send me code.
thanks!
Feb 04, 2011 | Nokia 6303 Cell Phone
Parrot CK3100 won't import Contact list from Nokia 6210 Navigator
Try this.
* To send several contacts at once:
* On the phone go to MENU / CONTACTS
* Select a contact to send by pressing OPTIONS / MARK-UNMARK / MARK
* Select your contacts to send then select OPTIONS / SEND BUSINESS CARD / VIA BLUETOOTH / MORE DEVICES
* The phone will search for available devices
* Select the CK3100 from the list and the contacts are sent to your car kit
Nov 13, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How to make caller names show when contacts are in with name and number
Make sure your contacts are saved to the handset not the sim
this is because nokia handset only read the name and number from the handset when you get a call
so copy your contacts to the handset and this should work
Any Problems Contact Me On mjsnowdon007@live.co.uk
Michael (Mobile Phone Engineer)
Universal Mobiles Coventr LTD
May 28, 2009 | Nokia 6210 Navigator Cell Phone
Cannot unlock my nokia 6210 phone keeps saying error when l put in code.
U may try this website mobileunlocker.
In that site U can get the unlock code for this nokia 6210.
Apr 22, 2009 | Nokia 6120 classic Cellular Phone
Silence on voice calls on the nokia 6210 navigator
its a signal problem if your mic and speaker work fine the rest of the time. you can order a replacement internal antenna off line by completing a google search for nokia 6210. find a supplier of your choice. when you make a phone call the towers immediatley know who your calling and where you are. but if your signal strength is extremely poor, the system will complete the connection even though your device is no longer sending or receiving completed packets of data. (data doest stream, its sent in groups called packets) an interuption of these packets at a large enough level will stall any call, resulting in dead air. all you and the person on the other end will get is silence, and a counter showing that the call is connected, when in reality, the connection was never completely made. i suggest that if your device is under warranty to have it replaced or repaired by nokia. you can check the warranty status at this site: http://nokia.us/get-support-and-software/repair-and-recycle/warranty/warranty-verification
GOOD LUCK and pls rate this post
Mar 19, 2009 | Nokia 6210 Navigator Cell Phone
Name does not Display even after name is saved
Go to contacts option in menu and there selectmemory in use as both phone and sim... it will work... And don't forget to vote me...
Dec 28, 2008 | Cell Phones
Cell Phones Logo
103 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
