Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Plastic housing PT 50LC14 Plastic housing. I have the new bulb need help getting the housing apart
  • kadutwum Dec 12, 2007
    I have panasonic PT-50lc14 and need to replace the lamp. I have the new lamp. how do i remove the housing to replace it?
  • Anonymous Jul 19, 2008
    how do you disassemble housing for tyla1000 boulb replacement
    Problem Solver:
  • 3 Answers
Plastic housing - moz-screenshot-1.jpgTry this link and download the manual. See page 81.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Posted on Dec 14, 2007
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
I have a panasonic PT-50LC14. the tv will turn on, but there is no picture. do i need a new lamp or bulb?
It is possible if over two thousand hours of use or two years, I would suggest at least removal and inspection to see if lamp shattered.
Sep 03, 2012 | Panasonic PT-50LC14 50" Rear Projection...
How do i get lamp out off housing
lamp and housing are sold as one unit..remove screws and replace whole assembly.lamp is made of quartz.handling bulb will shorten life of silver halide bulb.bulbs wires are usually connected with screws if replaceable or could be crimped on.too hot to be soldered on
Feb 18, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 has evenly spaced vertical blue lines aproximately 1 cm apart
it's not the light engine it'sd the bulb, replace that first, then clean it all out then go from there........
Nov 07, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Lamp
Ok, so you need an extra long drill bit. Put in the hole of the corners of the housing units and drill out the little screws. Then you have the take off the two screws attached to the bulb. Replace Bulb and put it back together the same way. It's best to use a magnetic bit or at least an extension that's magnetic to reach the screws. They are easy to take off, but will be harder to put on.
Jan 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
What screw do i actually loosen to remove the lamp in my pt-50lc14 50 in?
There should be 2-sets of screw for one panel and another panel with 1 screw. Unscrew the single screw. There will be another single screw that hold the bulb. Loosen that one and pulled the bulb out. Hope that helps.
Dec 03, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
165 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
