Question about Genius EasyPen (K9418400)
Cable color to connect to serial port. EasyPen FCC
I broken cable my cable i need know whats cable color to connect to serial port. EasyPen FCC ID FSUGEPEN
How to manage Ericsson T720G switch?
(1) Console cable if you have desktop
http://www.instructables.com/id/Simple-RJ45-DB9-Cisco-console-cable/
For laptop console to serial cable
http://d32plhejlomyli.cloudfront.net/catalog/product/cache/6/image/500x500/9df78eab33525d08d6e5fb8d27136e95/1/4/14184.jpg
(b) Reset the switch it will work as a normal switch
skype id johnwalker800969@gmail.com
Aug 18, 2016 | Computers & Internet
Can you repair the charging port and button on the LGL86C?
Charger port or cable to charge with?
Check with a known working cable and if it still does the same you might need to send to the manufacturer to repair the socket
Nov 04, 2014 | LG Cell Phones
How to connect Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) to pc to get sound?
you need a cable 3,11 to 3,11 plug conector , buy it the price is like $3
concect to the audio port of the tv card behind and conect the other extremo to the pc sound card , and play it
May 31, 2014 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a cobra nightwatch classic and i cant get it to key in and i have an antanna and a coax cable buut i cant get nothing out of it FCC ID-BB03K229LTD SERIAL ID-804124807
Hi michael, my name is John. Welcome to FixYa. Try a different mic first, then if that does not work, then we will look at the transmit section. Let me know and I will post the tools needed to do the job here. Thanks for choosing FixYa....John
Nov 30, 2010 | Cobra 29 LTD CB Radio
How do I get the caller ID information from the Panasonic KX-TA824 through the serial port connection, in real time? I connected a serial cable from the unit to my computer, and it shows the call log,...
The correct answer is, "you don't". The TD and greater series (including the TAW) has a "AN" and "RA" feature that pre-displays CID as the call is ringing, the TA and lower does not.
Carl
Oct 10, 2010 | Panasonic KX-TA824PK Phone
Not charging and no light saying it is
There is a possibility that the battery could not be taking the charge, but typically the light is red while charging and green when done. Sometimes if the is fully drained it can take up to 15 or 20 minutes before the red charging light comes on. Try leaving it charging for 24 hours.
May 05, 2010 | LG HBM210 Bluetooth Headset Wine Red Color
Marantz PV-5580W Color Problem, Missing Red?
I have the same model however my screen is red w/ green lines. Did you find a fix to the problem?
Jun 30, 2008 | Marantz PV-5580W 55 in. Rear Projection...
Genius EasyPen (K9418400) Logo
279 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Mirca Sekosan
Mirca Sekosan
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
