Question about Black & Decker Garden
I have a lawn hog electric lawn mower and had to take the blade off to get it sharpened and now the blade does not want to go back on. I am looking for a parts break down on it and can't find it. Can you help me? Andrea
SOURCE: Problem mowing my lawn.
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Posted on Sep 01, 2008
rwvanlue
  • 486 Answers
SOURCE: how do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Posted on Nov 12, 2009
  • 15 Answers
SOURCE: can't figure out how to change it or take it off for sharpening
First and foremost, remove the spark plug wire. Turn mower on it's side, find the right size socket for the bolt in center of blade that holds the blade. If it wont loosen spray with WD-40 and let soak a while, then try again. Once loosend remove old blade, clean bottom of deck where blade fastened, then replace new blade and thoroughly tighten as tight as possible without stripping. Return to upright position and allow to set for 45 minutes to allow oil to drain back into the crankcase to prevent damage. Then reattach spark plug wire to spark plug. Do not attempt to start until oil has had time to return to the crankcase. Do not forget to remove spark plug wire before you attempt to replace a blade.
Posted on Mar 25, 2010
  • 52 Answers
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Posted on Apr 15, 2010
  • 38 Answers
SOURCE: RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Posted on Jul 04, 2010
The direction of the blade changed and now spining wrong way
being electric, I tend to think maybe the electric plug may be in the receptacle backwards.
Jun 12, 2013 | Black & Decker Black and Decker Mm575 18"...
How to hold shaft when replacing blade
You should hold the blade while loosening the bolt that holds the blade.
Jim
Aug 05, 2011 | Black & Decker Black and Decker Mm575 18"...
Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
May 26, 2010 | Black & Decker Black and Decker Mm575 18"...
Elect mower blade replacement
mower, then blade, then plastic part, then metal square washer, then nut
Apr 23, 2010 | Black & Decker Garden
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Lawnmower blade turns but does not cut
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Aug 01, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I need to get the blade of the lawn mower sharpened.Any tips on how to disconnect the blade fropm the lawn mower?
There is a jig that you can buy that makes this job SO much eaiser. It is a universal jig that clamps onto the deck and keeps the blade from spinning so you can use a ratchet to remove the nut holding the blade on. One name brand is called a "Blade Hog". You should be able to find one of these at one of the bog box hardware stores.
Hope this helps,
Chad
Nov 09, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
