Question about Electrolux E23CS75DSS Stainless Steel
My model E23CS78DS wil not cool. The compresor or the cooling fan will not kick on. The interior fan and the lights are on inside. When I set the temperature to 0 and 37, it wil kick back to current temperature. Please tell me what I am looking at needing to do or replace. Thanks, Michael.
    Passionate:
    Visited the website for 10 consecutive days.
  • 106 Answers
There are three variances of this model ending in S0,S1 or S3 after the last S you provided so you might have a variable speed compressor or a single speed.
It sounds like a single speed.
At the compressor you should have either two or four wires going into it with the light blue and the black being the line voltage (110v ac) and the smaller red and black being the low voltage signal to the variable speed if applicable (4-12 vdc)
It sounds like you have a bad control board and checking voltages will tell if that is the problem. It is located behind the kick panel in the front on the left side and will usually smell/look burnt when removed. The part number may change depending on if it is a S), S1 or S3 so check with your local parts store. (get the model# off of the sticker inside the unit and not off of the owners manual as it is incomplete and sometimes wrong).
My model E23CS78DS wil not cool. The compresor or - r0506072-00003-ugpmwzkozlpwpbifstbx1xm5-1-0.png
Posted on Feb 15, 2018
2 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Oven Switching Off
I have a few questions. Does the oven reach the set temperature? How do you get it to go back on? and if you do not set the time do you have the same problem?
Posted on Dec 06, 2007
LG model TS-K2430hl .Outside fan stops after a few min.
Should like your unit is working fine unless this is constantly happening. If this is a constant thing then condenser coil if dirty,check thermostat setting
Dec 16, 2017 | LG Heating & Cooling
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
The frigerator & freezer are not cooling properly . i hear the compressor running . i have also diconnected cleanned inside and out but still the unit is not cooling properly . even on higest settings
If the compressor is running almost all the time (and the compressor sounds ok - no pinging/clunking),
then your side-by-side has developed a coolant leak.
When a system is low on coolant, the thermostat detects the warm condition of the refrigerator, and
runs the compresor motor in an attempt to cool off the refrigerator compartment, but if there's little
or no refrigerant in the system, the system's attempt to cool off the refregerator/freezer will fail,
with the symptom that the user wil hear the compressor motor running constantly.
May 13, 2011 | Kenmore Side by Side Refrigerator
Interior light stays on...light is hot..food directly beneath light is not cooling
HI. There is a door switch that controls the interior lights. This switch is also connected to the fan motor circuits. The actual door switches will be the lone culprits in your case. They are not functioning at this moment. This switch fault will effect the cooling process and cause an abnormally high temperature inside the unit, due to no Evap fan action and interior light heat.
Simply replace the door switches to correct the issue.
Sep 04, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
I have a kenmore elite , Mod# 71203100 mfg=10/10/2001 it worked fine since I got it ..48 hrs ago it was found to be not cooling anymore, lights go on fan's work , but compresor will kick in for 30 sec and...
I would fix it because The way I am understanding the compressor is getting hot and thermally kicking out. This could be a thermostat or a start relay for the compressor. Or it could be low on charge that will also make the compressor shut down because of the head pressure. I would check out my thermostat really close and any start relay's for the compressor. It would be about 200.00 compared to 1200.00 to replace it.
Jun 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Not cooling - sounds like something is trying to start then clicks off
Try first replacing the relay(located on the side of the compresor)wich the part won't cost more than $20.If doesn't work the compresor is stuck or burned and you need to replace it.
Apr 19, 2009 | Refrigerators
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Electrolux E23CS75DSS Stainless Steel Logo
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Sal De
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
