Question about Kenmore HE2 Plus Front Load Washer
Odor in kenmore front loading washer
Brown substance in rubber door gasket
  • 15,935 Answers
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Was cleaning rubber gasket for mold and noticed when I cleaned inside outer lip of steel drum a lot of brown sludge-is this grease for drum or is this build-up of some sort that should be cleaned? Also-do...
The brown sludge you are finding should NOT be grease as the bearings for the drum are sealed. This may be soap scum build up, and a combination of mold or mildew if you have been leaving the door shut between washes. It is strongly recommended by the manufacturer that you leave the door open when not in use to allow the drum air out. This aids in preventing mold, mildew and odors. The following link explains some of the common causes of front loader odors and how to remedy the problem:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
As far as the water fill hoses are concerned, the hoses are usually good for about 5-10 years (rubber), 10-15 years (stainless steel). They usually only require replacement if the rubber begins to crack or dry rot and/or begin leaking. A general inspection of the entire length of hose, cleaning the sediment screens in the ends of the hoses (if equipped) and replacing the gasket at the fitting will extend the life of the hoses. Replacing the hose has nothing to do with preventing odors. Odors are generally caused by not leaving the tub open to air out, using too much (or improper) detergent which causes soap scum build up, or a clogged drain trap. The following link explains how to access and clean out the drain trap:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
I personally own a washer similar to yours and have never had any problems with mold, mildew, or odors, by following this regiment. If you have any questions or concerns, please post back and let me know. I hope you find this information helpful.
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can the rubber gasket between the drum and door be removed for cleaning...it tends to become very moldy.
it can be but don't reccomend it unless you have done it before such as a repairman.  i have found that cleaning it with bleach usually does the job.  you may want to also run about 1 cup of white vinegar through a hot water load by itself and that should alleviate any odors for the most part.  you can also by a product called washer magic at most stores.  made specifically for cleaning front loaders.
Aug 02, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Mold remain in rubber rim of washer
Hi Qqiustin.There are couple of solution for this,you can try that before attempt to change door gasket.1- Run machine empty on Cotton 95C cycle,while it's intaking water add 300ml of bleach.(It could produce some foam but let it go & finish it's cycle)That progress will clean your machine & mould on the door gasket should get disappeared.Alternatively you can try EXIT MOULD or likely products on the super market sells.Follow the instruction.Goodluck.Thanks.
Aug 02, 2010 | Miele W1926A Front Load Washer
Kenmore Super Capacity 3.5 Front Load Washer leaves dark lines on light-coloured items and light lines on dark-coloured items! I've cleaned the rubber gasket (? where the door fits into the drum) and there...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Jul 13, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
We've had our HE 2 plus washer for a couple years, and we have started to smell a slight mildew odor. Is there a trap someplace that needs to be cleaned, or something else I need to be looking for?
You need to use some bleach and clean the washer out. I also wipe the rubber around the door opening and leave the door open airing out the machine. The rubber gasket will grow black mold.
Aug 13, 2009 | Kenmore HE2 Plus Front Load Washer
Hard, unidentifiable substance in washer
with almost all front load washers you have to remember to run clean cycles due to moisture in unit and door constantly closed they get mold and mildew along with debris from washing it can leave very strange looking deposits on the front rubber area because it collects these things.Suggest running unit with bleach and no clothes several times to get rid of foreign matter inside and leave door open after to dry interior out overnite and one more bleach cycle in morning and should be good to go after.Refer to manual from this point how often to running clean cycle.
Mar 25, 2009 | Kenmore 42822 Front Load Washer
Kenmore Elite Front load washer leaking
You need to replace the rubber gasket around the door.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Water Remaining in Gasket Around Door
normal problem all front loads all brands.. leave door open as much as possible.. to clean fill tub with hot water pour in 2 cups chlorine bleach use rag in solution wipe gasket out as good as possible allow washer to run normal cycle ..do as routine when ever odor is first noticed leaving door open will allow most of water to evaporate
Nov 19, 2008 | Kenmore Elite 45986 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Replacing the rubber gasket on Kenmore elite HE 3t
probably some rubberize installation are screw to the case or body/ you only need pollout are screw driver philips or flat .
Jan 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
465 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
