I have a kv-30hs420 and I'm trying to watch blu-rays through my PlayStation III. The HDMI cable is hooked up and the TV is on Video 7. I'm getting audio but no video. I've tried every setting in the menu and nothing seems to work. Suggestions?
AmigaDude posts how to reset the video to factory settings here: http://www.avsforum.com/avs-vb/showthread.php?t=766771
The instructions are as follows:
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Once reset, you'll connect your RCA cables (Red/White/Yellow) and set up the PS3 display settings. To get there from the XMB bar, go to Settings > Display Settings. You might have to disconnect the HDMI cable from the PS3 before the RCA cables work. I don't remember entirely.
Select Video Output Settings > HDMI > Automatic. If you can see the prompt about a max resoultion of 1080i (with your HDMI cable plugged in) you should be good. Select Yes and press X to continue. You can set up the audio but it's not necessary. Select Finish and you should be good.
