Question about Mtd Garden
I have a riding mower and the steering shaft goes to a deck,the phillips screw and shaft is loose but will not brake loose. there is a gear at the bottom of shaft and this turns the wheels it is not touching. because it is so loose. anybody have any ideas.
  • 41 Answers
I have a yardman that had a similar problem, there is a spacer/gromit at the end of the shaft just above the gear this needs to be in place to hold the steering shaft straight.
Posted on Jul 15, 2009
  • Bill Bowres Jul 15, 2009
How do I remove the steering shaft on Yard
You could use an impact screwdriver. Use a #3 phillips bit if the screw is large. You smack the end of the impact screwdriver with a hammer and the action pushes in and turns on the screw.
Sep 20, 2014 | Garden
How to remove the steering shaft on a John Deere 125 Automatic riding mower?
should be enough room to get it ontry rolling it past the steering shaft
Aug 25, 2014 | John Deere Garden
Steering skips
Three things need to be checked. The steering shaft for play, the pinion gear on the end of the steering shaft and your stationary gear at the bottom. Raise the hood, turn the wheel back and forth so you can see where the play is coming from.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering gear slips
You have the steering shaft the pinion gear on the end of the shaft and the stationary gear at the bottom on the frame. Either the gears are worn out or the steering shaft has too much play in it causing the gears to slip.
Steering is loose. How to tighten it?
Joseph, Most likely it is the bronze bushing at the other end of the steering shaft. You will need to remove the mower deck to access it more easily. The steering gear could be replaced at the same time if you want, you will be right there at both the bushing and the gear, the sector shaft hopefully is ok. You can view this with a flash light before disassembly. It is on the steernig shaft that goes behind the fuel tank, down into the frame. As you or a helper turn the steernig wheel back and forth, you can see the engagment of the steering gear and the sector shaft, to determine if they need replacing too. Your dealer should have a dozen or so of those bronze bushings. Its not a bad job to do.
Matt
Nov 09, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
Steering wheel gear is stripped
Please for the love of god tell me you have an answer to this, same problem, sooo angry, hit me up at reid72@aol.com pleeeesee
Jul 15, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cant remove steering wheel from john deere rx 95 lawn mower
At the bottom of the steering wheel you should see a screw that goes crossways through the steering wheel and shaft. It will have a nut on one side and a phillips head on the other. Do not try to unscrew this bolt! Use a punch and tap it out from the nut side being careful not to damage the end of it. It is serated and will not turn with a phillips screwdriver. Once this is removed the steering wheel should just pull off. If it doesn't, post your model/serial number and I will check to see why.
Sep 23, 2009 | Garden
Garden Logo
643 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
