Check power supply voltages to run convergence amps....usually
around 20 volts + & --........should be present at the two watt
resistors....beyond basics,you might need a diagram to trace
the path of the blue horiz & vert....might be an open connection somewhere.........also, check for an open pico fuse.....not too
likely,tho,becuz of the symptom.....You might take the time to go over your own work,....I often backtrack when I get the same
as before.........Let me know.................T.
Same exact problem here. have not looked into fixing yet. Is it worth it to try to fix? How much on average would it cost? I see alot of the same problems with this t.v. WHY? Please help.
Thanks
