Elitegroup Computer Systems (ECS) Support > ECS L7S7A2 > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=267&MenuID=24&LanID=0Click on Download.
(Features /Specification / Download / Support / FAQ / etc)
Click on Manual.
(Driver / BIOS / Manual)
Scroll down a little, click on the country name nearest yours, next to the Green Down Arrow.
A small window will come up on the right -
Opening l7s7a2_eng11a.zip
Make sure there is a Green dot in the small circle, to the left of - Save File.
If there isn't; left-click in the empty circle to the left of Save File.
Now go below in the window, and click on OK.
A small window will come up on the left.
Allow the file to fully download, then DOUBLE-click right on the file name.
In the next small window click on - Extract all files, to the far left.
In the next three small windows click on Next, Next, and Finish.
Finally in the last small window, DOUBLE-click right on the file name, next to the red Adobe PDF icon.
(L7S7A2_en...)
There is the motherboard manual, and the jumper settings.
IF, you cannot open this Zip file, suggest go to 7-Zip, download, and install. It is a free 'un-zip' program.
[ A Zip file is used to send large amounts of information more easily.
A Zip file is a compressed file.
You need to 'un-zip it', or uncompress it.
Requires an 'Un-zip' program.
WinZip usually comes with Windows, but may only last so long, because it is a trial version.
7-Zip is one of the free unzip programs, NO trial.
I use it ]
[NOTE*
I DOUBLE-clicked on the file name - L7S7A2, and a warning 'Squawk Box' came up from Microsoft.
Click on Run. It is OK I assure you.
[ Small primer;
Microsoft assures users that the program they are about to use, is free from Malware. (Virus, spyware, etc)
To do this they check the program out, and certify it to be OK.
This cost $$$$$$ for the software manufacturer.
Costs for the main program check, and EACH time a user downloads the software.
This = NO to most software manufacturers.
Most of the time the software is free, WHO in their right mind is going to pay each time a user downloads it? I wouldn't.
Also if I am a reputable software company, or pre-built computer company, I wouldn't either. ]
IF, somehow you cannot download the motherboard manual:
Motherboard oriented as it sits mounted in the computer case;
Processor to the Top, Ram Memory slots to the Right, 5 white PCI slots to the Bottom;
1) To the Left side of the Processor socket is a jumper.
FIDJP1
CPU (Processor) Ratio Selector
(Multiplier)
Two columns of 5 contact pins.
Contact pin on the Bottom/Right is Pin 1.
Pins on the Right side are numbered ODD.
Pins on the Left side are numbered EVEN.
Starting on the BOTTOM of the Right side, going towards the Top;
Pins 1, 3, 5, 7, and 9.
Starting on the BOTTOM of the Left side, going towards the Top;
Pins 2, 4, 6, 8, and 10.
Jumper on pins;
A) 1 and 2 - BIOS checks the Processor out, and automatically sets the Multiplier. (CPU Ratio Selector)
B) No jumper used -> 10.5
C) Jumper on pins 9 and 10 -> 6.5
D) Jumper on pins 7 and 8 -> 8.5
E) Jumper on pins 7-8, and 9-10 -> 12.5
F) Jumper on pins 5-6 -> 9.5
G) Jumper on pins 5-6, and 9-10 -> 5.5
H) Jumper on pins 5-6, and 7-8 -> 7.5
I) Jumper on pins 5-6, 7-8, and 9-10 -> 11.5
J) Jumper on pins 3-4 -> 10.0
K) Jumper on pins 3-4, and 9-10 -> 6.0
L) Jumper on pins 3-4, and 7-8 -> 8.0
M) Jumper on pins 3-4, and 7-8, and 9-10 -> 12.0
N) Jumper on pins 3-4, and 5-6 -> 9.0
O) Jumper on pins 3-4, 5-6, and 9-10 -> 5.0
P) Jumper on pins 3-5, 5-6, and 7-8 -> 7.0
Q) Jumper on pins 3-4, 5-6, 7-8, and 9-10 -> 11.0
The JP1 jumper is to the Right of the bottom white PCI slot.
(No.5 PCI slot)
3-pins going across in a row.
Pin all the way to the Right; is Pin 1.
Starting from the Right side, going towards the Left;
Pins 1, 2, and 3.
Turn computer OFF.
Put a jumper cap in Pins 2 and 3 for 5 seconds.
Remove the jumper cap, place back on pins 1 and 2.
Resets CMOS memory.
Just in case you are referring to the Front Panel header;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires go to, is the Front Panel header.
The Front Panel header is to the Right of the CMOS battery, and is located next to the right outside edge of the motherboard.
Two columns of pins.
IF, I am reading this correct; 5 pins on the Right side, 4 pins on the Left side.
Starting on the Bottom of the Left side, going towards the Top;
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive connection.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. It is Reserved. (Probably 5 Volts for the factory to test )
D) Pins 2 and 4 are for the Power On LED. (Light)
Pin 2 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://www.ocworkbench.com/2003/ecs/l7s7a2/l7s7a2-1.htm
