Olevia 32" 232v 1080i widescreen lcd hdtv black Logo
J
John roy Posted on Sep 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Olevia picture comes on but nothing else works? Dvd not working and cable box on...rebooted all and unplugged all for 5 minutes, still same problem. Any suggestions? Any reset feature on this tv?
NoName Jack
Level 3:
  • Olevia Master 1,150 Answers
  • Posted on Sep 13, 2015
NoName Jack
Olevia Master
Level 3:
Answers
1150
Questions
Helped
232952
Points
4657
Hi John
Your on the right track
It's just a computer internally
Finding the key sequence to get a RESET is the key
or if there is an internal button battery... remove it
How to Reset an Olevia 226 eHow
How can i get my olevia to turn on it keeps saying no signal. had a storm and it went out
Do you know for sure if the cable box is out sometimes you have to reset the box . usually if you unplug the box for a couple of minutes it will reboot that may do it or try rebooting both at the same time when power is off it really isn't as the units keep current available for instant on that's why its a good idea to unplug most of your appliances when going away. check out the rebooting that should do it
Can't switch back to cable after using dvd
Disconnect the DVD---if using a box disconnect it also---run cable to the tv directly to see if box is causing the issue.
If works with cable direct to set unplug the box and after a short wait plug it back to let it try to reboot.
If reboot does not work consider having the box swapped out.
1helpful
Audio dosn't always come on when powered up
Check connections first and if ok and using a Cable or Sat box unplug that and power it back to see if a reboot will cure this---depending on how you are connected if using a box it may be also a defect in the box.
To try to narrow this down test to see if problem ever happens with a DVD etc hooked via rear audio and video jacks.
No tuner signal
Unplug the set and a box if used and then after a short wait plug both up to allow both to reboot.
If using the coax fitting on set you can with a box connect to rear inputs and bypass the problem= ie if the rear jacks work with a DVD etc.
SOUND BUT NO PICTURE - Philips 42PF9631D 42 in.
Unplug the box's power cord for 5 minutes and wait for it to reset, plug it in, wait another 3 minutes for the box to reboot, then power up the box. If that doesn't fix it then you might have to call your satellite/cable company.
5-digit universal remote code for olevia 532h
No such thing. Your best bet is to watch various deal sites and get one of the less expensive Logitech Harmony remotes, all of which can easily control your Olevia, as well as your set top box (cable or sat), DVD player, receiver and any of over 100,000 pieces of av equipment -- including eveyr product Olevia made before going defunct.
Olevia 242T 42" LCD HDTV - Suddenly No Picture, Nothing Works
 I heard they were restructuring their company or something.
There has been a change ownership from Syntax-Brillian to Olevia International Group.
Details of Olevia brand
Unfortunately for all of us (we have 747i) service seems very poor and the failure mode you describe doesn't give me any clues despite 40+ years of service experience.
Ours is still 100% but I now suspect our trouble will come.
Pdp6100hd tv audio visual not working
unplug the cable box for 1 minute then plug back in and let it reboot.
Popping sound
In our area this is commonly the cable boxes. Does it occur on DVD or other sources? If not:
Reboot your scientific atlanta cable box by unplugging it from the wall for a few seconds, then plug it in and wait about 5 minuites for the time to come on again before use.
29helpful
13answers
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
