Question about RCA P46924 46" Rear Projection Television
No sound - RCA Home Theater Projection TV.
I have an RCA Home Theater Projection TV. The sound went out in the middle of a cable-broadcast show. We had not touched a thing on the set or the remote.
The TV is definitely not on mute, and the TV volume at about 1/4 of maximum.
You can hear white noise when you turn the volume up to max.
All the cables (co-axial and jumpers) are pushed in tightly.
There is a DVR/VCR combo connected between the cable line and the TV. There is no sound when we play that unit either.
I rocked the unit back and forth gently to pull it out from the wall so I could see the back.
The only other time we have had trouble, the repairman said there was nothing wrong except an intermittant loose connection. The last time we had this particular problem, the sound came back on by itself.
5 Suggested Answers
  • 150 Answers
SOURCE: TV will not turn on
Probably needs a new HV Splitter block, they are very difficult to replace and can usually be accessed thru the front behind the speaker grill and behind convergence board.
Posted on Jul 27, 2007
  • 205 Answers
SOURCE: no sound when connected to dvd player
If it's only connected with component video cable (Red, Blue, Green) cable set then no audio has been connected. You will still need to run a set of audio cables (usually White and Red). The other option is to use Composite cables (Yellow, White, Red). A composite cable set has the video on the yellow cable and the audio on the white and red. Component video breaks the video into the three channels.
I want you to know that I'm not paid for this, I just like trying to help. If I've misunderstood your question or this information does not solve your problem I'd be happy to try to help more. If you do find this information helpful I hope you'll give it a positive rating. Thanks and good luck.
Posted on Jan 01, 2008
  • 10 Answers
SOURCE: RCA P46924 64" Rear Projection TV
disconnect the wii it will eventually ruin your tv game systems can't be used on rear projection because of problems caused you may need to hook everything up at the bottom of the panel and switch back and forth using your remote we had to do that on ours
Posted on Oct 23, 2008
inc_evil
  • 12 Answers
SOURCE: I have an RCA rear
it depends on how you have the box hooked to the tv, is it via cable (co-ax) connection or rca (red yellow white) cables ? You may have the audio hooked wrong or it may be a blown input in which case switch to a new input on the back of the tv (possibly the one you used for game systems). If ur using a co-ax connection from the box try rca cables and if ur using rca try co-ax. If none of this helps call ur cable provider and tell them the box doesn't have any audio and u know it's not ur tv. Usually they will come fix it 4 free and try n educate you to what went wrong.
Posted on Mar 16, 2011
I have an RCA rtd315w home theater system and I am trying to connect my xbox to it so it will play the sound. I have my xbox connected to my tv through a component HD cable. How can I get the xbox sounds...
run yellow cable from xbox to TV vide input for picture!, now run the red/white cables to AUX ibput on the RCA and push function till you see aux and poof, you got Video on the tV and audio from the surround sound.
Sep 05, 2013 | RCA Rtd315w Dvd Home Theater System...
How do I connect my Coburn home theater to my Sony 52 inch projection TV I tried but get no sound
if the coburn has a scart interface u willl need a scart cable that terminates to rca the simple av vcr cable jack then ;ug the scart end to the theater and the rca to the tv front jack inputs n u ae ok alternatively get a hdmi cable that terminates to rca and connect the hdmi end to the theater and the rca to the dvi/ dvd/compoment input remember sony use icons not words for there accessories for audio input the icon is an in-arrow to a square box and output an out-arrow from a square box select tv. dvd or component av before u start
Jul 19, 2013 | Televison & Video
I have a RCA RTB10223 model, and my problem is I can get the surround sounds to work with a movie in, but its not working with the regular TV. What do I to get it to work?
That is because your movie is in 5.1 surround or better. Over the air and cable broadcasts are not always broudcasted with surround sound, there fore you will not always get it.
Apr 26, 2012 | RCA RTD317W Theater System
I have rca home theater system rtd215 plays dvds fine but no sound when im watching tv programs i have no cable box just the jacks on my tv [52 projection screen phillips] and i tried hooking them into the...
This reson you are not hearing any "TV AUDIO" through your RCA surround system would be due to your tv sound output not being connected to an audio input into your surround system. You can hear DVDs,CDs and radio possibly mp3 if connected, as these are built in to the amplifier which the speakers connect to.
If the tv has a Line out (via phono plugs) and NOT via headphone out, connect it to an audio input on the RCA surround system. If the RCA has no other available inputs, well....there ain't a lot you can do but watch CSI with the sound from the TV and then Star Wars (for example) through the TV and Surround system.
Best Of Luck
Sep 03, 2010 | RCA RTD215 Theater System
We do not have the remote,we do have a radio shack 8 in1 univeral remote.which worked good until, we lost sound and picture,can not get into the program.channels change on screen.and home theater shows up...
I removed coxail cable from the tv and connected 3 rca cables between tv and cablebox, now have picture and sound.The problem is still there ,something has blocked out my internal cable connection.
thanks Roy
Oct 07, 2009 | Televison & Video
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
No sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Nov 23, 2008 | LG LHT854 Theater System
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
Rca home theater problem
The trouble is the front panel buttons,unplug the unit and remove the back cover,just below were you removed the top screws,you can look under and see the top of the tubes,there is a small board in front of the middle tube,unplug the right top cable off this board and you can use your remoten till you can get it serviced
Oct 01, 2007 | RCA P61927 61" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
145 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
