Question about Frigidaire ATF6000ES Front Load Washer
It keeps saying the door is open when it is not, and will not run
I get a "dr" code and the machine will not start. Is there a sensor I can replace?
I have unplugged the washer and then plugged it in to see if that cleared the machine and tried it and no change. We also held the start button down for 30 seconds and no change with that.
  • Frigidaire Master
  • 3,361 Answers
Change out the door switch and wax motor assembly.
Posted on Jul 12, 2009
What is the sequence to start diagnostics running on my Kenmore Elite washer #417.41102000?
DR means that there is a problem with the door. It might be the switch that tells the machine the door is closed all the way
Sep 11, 2014 | Washing Machines
I'm getting a door error "dr" on my ATF6700SF0 washer. How can I determine whether to replace the door lock assembly or the control board?
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire ATF6700FS Front Load Washer
Dr code after replacing door latch/ switch
when you crank it over for a while the tbs fault light come on is that the computer that runs the pressure
Feb 12, 2013 | Frigidaire Washing Machines
Error code DR comes up on my Frigidaire Affinity and won't keep running
It is telling you there is something wrong with the door lock assembly. You will probably have to replace it, but check it first for a broken wire or some other problem that you can fix.
Here is a link to the part if you need it.
Here is a link to a service manual for your machine that will take you through the testing and repair process.
http://www.emaservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
Oct 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire leq2152eeo error code dr
Hi - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Oct 06, 2012 | Washing Machines
It says dr and beeps on my frigidaire front load washer
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gas dryer with error code dr.
Dr or DR is a generic door error code. Either the door is not shut properly, door is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 18, 2012 | Refrigerators
Close door push start and it says door
Possible that the door safety switch is not contacting and is defective. Remove power and check from inside the unit for the continuity of the door switch.
If open it can be shorted for a trial run to confirm and then replaced.
Jul 05, 2012 | Frigidaire Washing Machines
Washer won't start and DR displays
means door is open. If door is infact closed, i would say you have a faulty door switch. Replace and test, part number is 131763202
Apr 07, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
