Question about Sony VAIO PCG-K35 Notebook
Shuts down on AC in less than 3 minutes after boot but not in safe mode. Works fine on battery only. Charges battery fine. DC output voltage 19.77 VDC. Sony Vaio PCG-K35
  • 788 Answers
Sorry about your SONY problems.
You may want to try another charger,
Your charger changes your input voltage from A/C 120V / 220V to a constant regulated 19.77 ? Volts DC. or direct currant.
If your charger is allowing to much A/C to pass to the Unit, the unit may charge OK but with sense the incoming and as a protection, will shut down the power source.
I would take the charger to a Radio Shack or maybe someone qualified to check it !
If the charger is fairly old and you live in a lightning area, this may be the case.
If your unit will run without the charger attached, Boot it up regularly ( not in safe mode ) and make sure the battery if not at fault.
If you have a battery check utility !
Hope this information has helped you with your problem.
John Ray
john@johnrraycomputer.com
Readers, please rate your technicians information.
Posted on Jul 12, 2009
Having trouble with all my speakers except my twitters in a 2007 Saturn Outlook...what do I start with? Fuses are good
Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
Dec 25, 2016 | Saturn Outlook Cars & Trucks
Laptop shuts down prox 1 minute into startup.
Did you check if the fan is working, and temperature is ok, you need to use a software
Apr 04, 2008 | Toshiba Satellite A105 Notebook
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
When u turn on the power the power is on but it will automatically turn off.
1. Please check the power on button. whether the button is still in pressed mode, or releasing the button.
2. Check the AC power adapter output with multimeter in DC range, Whether the voltage coming out is correct or not. Output DC voltage is written on the adpater.
3. Remove the battery and power on laptop with AC Power. with out BATTERY.
4. Clean the air vents near the processor and other vents for proper cooling.
Jul 04, 2011 | Toshiba Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
May 14, 2010 | Acer Aspire L100 PC Desktop
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Laptop boots then shuts automatically off
Try this, if you have a fast hand, the second it boots, push Ctrl+Shift+Esc and end taskeng.exe.
If you can't do it fast enough, try booting into safe mode, going to scheduled tasks, and removing any suspicious ones.
If you don't know how to boot to safe mode, push f8 until you see a screen which allows you to choose safe mode.
Dec 18, 2008 | Toshiba Satellite P105-S6177 Notebook
HP DV9000 Display Works with battery not AC almost
Have you checked whether the Power Adapter of your Notebook is a 65 Watt or 90 Watt ??
If you are connecting a 65 Watt adapter with the Notebook, try wiht a 90 watt one from any other Notebook if available..
Notebooks with Nvidia Graphic card need a 90 Watt Power adapter to supply the adaquent power required for the Graphic Card and a 65 Watt adapter may not be able to supply the required power.
Aug 03, 2008 | HP Pavilion dv9000z Notebook
Sony VAIO PCG-K35 Notebook Logo
194 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
