Question about Hampton Bay 46056 Callaway II Ceiling Fan
Goes only at a slow speed - Hampton Bay 46056 Callaway II Ceiling Fan
    Problem Solver:
  • 10 Answers
Some ceiling fans only operate at one speed. (Wanted more detail? Then give more in problem descriptions!!)
Posted on Jul 12, 2009
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
When i start my proform 750 it doesnt slow down. It goes straight to max speed and never slows down.
try to calibrate the speed on the treadmill look in the trouble shooting section of the manual
Nov 04, 2014 | Proform 750cs Front Roller Model 299560
In my toyota yaris, when i use breaks in low speed my car goes slightly forward, then breaks works.
Check the condition of the pads, disks, and operation of both. They should be freely moving.Also check that your brake lines are free of air and that your fluid is clean.
Also check that the vacuum line to your brake servo is intact, and that you have adequate vacuum to your servo.
Nov 18, 2012 | Toyota Yaris Cars & Trucks
Check transmission light is on, Drive light flashes, car moves really slow when u accelerate and speed deometor never moves past 0
Looks like the speed sensor cable that attaches to the transmission is disconnected, or sensor is shot, hence no speed readings. Transmission module needs to know actual speed for shift patterns, if it does not receive any readings, it goes into a slow "safe mode".
Mar 20, 2010 | 1992 Honda Accord
Their is a truck with slot of torque, but slow.
if it really does have tons of torque but just goes slow you could change the gearing in the rear differential.
Sep 15, 2009 | 1988 Chevrolet K1500
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
My phones speed goes down.
Switch off your mobile and switch it on again. I this can help.
Nov 02, 2008 | Nokia N72 Cellular Phone
1999 ford tauras transmission and speedometer
Replace the speed sensor on the trans that will cause exactly what you describe is happening.
Sep 18, 2008 | 1999 Ford Taurus
Hampton Bay 46056 Callaway II Ceiling Fan Logo
195 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
