Question about Freezers
LEAKS WATER WHERE WATER LINE GOES INTO FREEZER.
ICE MAKER LEAKS WATER WHERE WATER LINE GOES INTO FREEZER SIDE ..
Is there a defroster for the inlet line at that point? If so is it replaceable?
    Champion:
  • 363 Answers
An easier fix is to redo the connection. Turn off the tap the supplies water to refrigerator, should be on your cold water line under the sink. Remove not on the solenoid valve(blue valve) slide the nut further up the vinyl tubing cut the tubing above the old connection. push the tubing into valve and tighten nut finger tight. turn the tap on a little and check for leaks at the solenoid. If no leaks open tap all the way. If leak tighten nut a little more only until leak stops. then turn tap on all the way.
Posted on Jul 26, 2009
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
Sep 16, 2013 | Sub-Zero Freezers
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Ice maker is not working. Our freezer fridge side by side is about 8 yrs old...and now the ice maker is not making ice cubes. It is as if no water is getting to the machine. I have turned the...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Freezers
The ice maker has stopped working
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 24, 2009 | Freezers
My jenn air freezer is not making cubes. the
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Jul 13, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
ICE MAKER NOT MAKING ICE, WATER NOT FEEDING INTO ICE MAKER
you may have a frozen inlet tube coming in to the ice maker. This is caused from a bad water valve and you would need to replace the water valve.
Apr 02, 2009 | Frigidaire Freezers
I have a Kenmore side/side with water dispenser and ice maker. Ice maker is not making ice, but I still get water. Every once in awhile I see a puddle under fridge (a large puddle). When I pull the fridge...
Hi TJ,
It'll cost around $65.00 to take care of this problem. The problem is the water inlet valve. The part number is 4389177 and can be picked up at your local appliance parts retailer or you can get one online maybe for a better price (just plug the part number into your favorite search engine).
Here's what's happening... The valve I mentioned is actually a "dual coil" unit. One coil supplies the cold water, the other feeds the ice maker. These "coils" are independant of each other, so one coil can fail and the other can keep on truckin', no problem. But what you have is an Ice Maker coil/valve that is weak and it's allowing water to bypass.
Basically the IM valve isn't closing shut completely. Imagine a dripping faucet... that's what it's like except you can't hear the drops, you can only see the results. Imagine drop by drop rising up that tube behind the fridge and into the IM. One drop at a time. These drops of water go into the freezer compartment through the IM fill tube. Now when these little ***** drops slide down the fill tube inside the freezer compartment they flash freeze before they reach the IM. One drop after another... drip drop drip drop. All these little droplets of water eventually form a glacier inside the fill tube.
OK, now we're at the point of glatiation. The fill tube (just behind the ice maker) has completely frozen solid. Now... when the IM "calls" for water to refill itself, the (failed) valve opens up and lets full pressure through. But where is this water/pressure going to go? The pressure builds inside the 1/4" water line until it can't handle it any more, the pressure looks for the path of least resistance. That path is the connection that you found loose. It blew out because the fill tube (into the freezer) is blocked with ice and the reason it's blocked is because the valve isn't shutting off completely.
That's alot of words to say this... it's an easy fix. Get the valve (above). Pull the fridge out. Unplug it. Turn the water off at the wall. Remove the water line going into the valve and set aside. Remove the cardboard panel. Remove the 2 screws holding the valve to the fridge. Pull the valve out. Note the electrical and tubing connections carefully. Get your new valve out and install the electrical and tubing just like the old one. Then rebuild, turn on the water and look for any leaks (use a flashlight and take a minute or two here... finding a leak now will save you alot of misery later). Replace the cardboard and plug it back in.
There ya go! Your first major appliance repair job done successfully? Priceless.
SG
Mar 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
182 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
