Question about Frigidaire Dishwashers
Dishwasher not draining sometimes, airlock maybe.
I just installed a new drain hose on my Fridgedaire dishwasher because it had a pinhole leak. Now it drains sometimes, but most of the time it pools in the bottom of the dishwasher. I've been reading about air locks and having the drain hose going about 20'' high. Tell me how to avoid airlocks in the pump and hose, thanks.
  • 6 Answers
SOURCE: diswasher airlock
By the airlock , you mean the air gap? .If the water is coming out of you air gap that means the hose that connects the air gap to your drain is clogged or your drain itself is clogged.Check the hose that connect the air gap to your drain(or disposer), check air gap and clogged disposer opening
Posted on Aug 15, 2008
  • 171 Answers
SOURCE: Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
  • 1462 Answers
SOURCE: Bosch Dishwasher Drain problem
check no blockage in the spigot in the garbage disposal and also that fat has not congealed in the drain hose
Posted on Nov 10, 2008
  • 22 Answers
SOURCE: Jenn Air dishwasher leaking
the emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Posted on Jul 19, 2009
57 varieties
  • 1653 Answers
SOURCE: Dishwasher doesn't drain
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
Posted on Sep 10, 2009
Bosch dishwasher
,ake sure when it was installed the hose is not higher than the discharge drain, it will create a vacuum and it wont drain for airlock, that's all.
Jan 28, 2014 | Bosch Dishwashers
Hotpoint diswasher won't drain or switch off and is constantly flashing f-2 , model is FDYF 2100 K
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
see the diagram attached, and proceed according.
May 24, 2013 | Hotpoint Dishwashers
How can I get to the inside
If your dishwasher is Leaking check the following
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your diswasher
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. .
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Drain:
This is usually caused by a syphon effect or your drain line improperly installed. You can not attach your drain line from the dishwasher without having a loop in it. If you go directly under the floor with your drain hose, all water will drain out upon fill. Safest and recommended installation of drain hose is to your kitchen sink and attach the hose somewhere so it is higher then the bottom of your sinks.
be65763a-411f-4910-88d8-4712ce0a8d7e.gifda9b96d7-ebd5-4e03-8f4c-4d0c49063e70.gifGod bless you, Use the VOM very important
Apr 05, 2013 | Kenwood Dishwashers
We heard a loud gushing sound and the dishwasher leaked all over the kitchen floor. Why?
The drain hose may have disconnected from the dishwasher or at the waste trap or the drain hose maybe broken.
If the drain hose is OK then the water supply hose may have disconnected from the tap or the water hose is broken and fresh water is leaking from this hose.
Jan 03, 2013 | LG LDF6810ST Stainless Steel Built-in...
The water is not emptying completely out of my dishwasher
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Sep 09, 2011 | Dishwashers
Dishwasher stops after 10 minutes inlet/drain light flashing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
New world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
Aug 24, 2008 | Stoves 27 in. DW60 Built-in Dishwasher
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Diswasher airlock
Dec 01, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
355 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
