Question about Mtd Garden
Mtd tiller is dripping oil from the main case
Possible leaking from seal on side of engine around shaft,mine does and on further inspection found shaft inside engine to be worn where it goes through outside cover.
Posted on Jul 28, 2009
Can you buy a service manual for mtd tiller
Every 25 hours change the oil using SAE30 or 10W30 oil. Go online to the manufacturer for service manual.
Aug 18, 2014 | Garden
After overfilling crank case with oil and fixing that issue. It is now very hard to pull through
remove the spark plug and pull the starter cord a few times. see if oil spits out when you do this. sounds like there is too much oil or maybe gas in the cylinder. let us know what you find after you do this.
Jul 10, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
I have an older 5 hp. Mtd tiller Do I have to use
Look on top of the machine.If there is an oil fill then no you do not use mixed fuel if yes it needs engine oil,30 wt.If there is no engine oil fill then you use mixed oil and gas,at a 50:1 ratio.
May 30, 2011 | Mtd Garden Tiller (Mtd)
Have 3 different plugs on the tiller. Which one is for the oil and what are the other two for?
2 plastic one's on front and back are to check and fill oil.
metal plug in bottom of case is to drain oil.
Jan 30, 2011 | Mtd Products Yard Machines 158CC Tiller
What kind of oil does the snow thrower use ?
if in your crank case it will call for 30 weight non detergent, thank you
Dec 19, 2009 | Mtd Products Yard Machines 158CC Tiller
I bought used mtd yard machine tiller it has 2 oil fills with yellow caps and 1 fill with a white cap what goes in this one?
The white cap is the actual oil fill, cause it's in a position where it's easier to pour oil into. The yellow ones are oil checks with dipstick, they all pour into the engine crankcase. You pour oil in through the white until you see oil come out of the yellow.
Just bought one myself.
May 02, 2009 | Mtd Garden
Need a manual
The unit uses straight 30w oil most manuals can be found here...Need Mod & Ser #
http://manuals.mtdproducts.com/mtd/public/list.jsp?BrandCode=10451
Apr 09, 2009 | Garden
Tiller won't start
Remove the airfilter and take a look at it. If it is dirty or has a lot of oil in it, that would explain why you can't start the machine. If that is the case get a new filter and you will be up and running.
please mark this answer as a fixya. thanks
Mar 18, 2009 | Mtd Products Yard Machines 158CC Tiller
Need to know the kind of oil or grease that goes in transmission
engine oil is sae 30
the the gear box I think is a 90wt
Mar 10, 2009 | Mtd Garden
Garden Logo
90 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
