Question about Garden
Replacing starting cord on Ariens ST622 string trimmer
The starting cord has come loose. How do I reset it
SOURCE: how do i restring the Ariens st 622 string trimmer
Cut two pieces of 18" commercial grade line - one to mount on each side. Look at the series of holes, two on bottom of rotating head, two immediately above but on outer lip of plate. Go up through the bottom two holes, even up your piece of line (like when you are putting in a new shoe string in a pair of shoes) and cross over then out through the top two. All done. If you are using an adequate grade of commercial line you can trim for hours over the roughest of stuff without worrying about restringing.
Posted on May 07, 2009
  • 120 Answers
SOURCE: Pull cord on TB25CS trimmer came out all the way, won't recoil
http://www.m-and-d.com/pdfs/MTD/TB25CS-41BDT25C063PL.pdf
Probably the recoil spring is broken.
Posted on Aug 24, 2009
  • 3 Answers
SOURCE: Need parts for Ariens ST 622 string trimmer
MY ARIENS ST622 starts but then dies down quickly any ideas?
Posted on Aug 28, 2009
  • 138 Answers
SOURCE: how much oil to fill a tecumseh 6 hp engine on an
This engine should take just alittle less than one quart. Doesn't it have a dipstick on it ? Irregardless about 1 quart should do it. Good Luck
Posted on Sep 09, 2009
  • 736 Answers
SOURCE: I have a Cub Cadet cc4125 string trimmer not starting
need a little more information .. but look for the following .. take out the spark plug and look inside with a flashlight ... if the piston is moving with the rotation of the flywheel then you likely have a blown head gasket .. if there is no compression there wont be a load on the pull cord .. a cracked or damaged piston can also do this .. ... if the piston is not moving when you rotate the flywheel then you likely have a bad "shear key" sometimes called a "shear pin" .. thats usually a half moon shaped small metal part that keeps the flywheel locked rotationally to the crankshaft .. it is designed to shear off if there is an excessive sudden load on the engine .. the flywheel will then spin without turning the crankshaft .. the same thing will happen if you have broken the connecting rod .. (a rod failure is often preceded by lots of clatter from the engine) .. the head gasket or shear key are much more likely to be your problem .. if you cant see in the spark plug hole you might try using a straw to feel the piston motion .. its possible that without the spark plug in place the piston might move even with a bad shear pin .. because with no compression the piston will move freely .. if thats the case you can stop the piston motion with a wood dowell thru the spark plug hole .. if it moves in spite of your dowell resistance then consider the head gasket option ..
Posted on Sep 19, 2009
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
What weight of oil is used in Ariens st622 string trimmer with a tecumseh 6hp motor
Since this is used in the summer any good grade is SAE30 oil will protect the engine..no need for muti viscosity oils..good luck.
Oct 02, 2014 | Ariens Wheeled String Trimmer - 946152
My 4-cycle troy-bilt string trimmer: string is locked up. I can not pull the string
Your String needs to be re-wound. You are almost out of string or your string has Jammed under the Motor and placing a DRAG on the Trimmer
Apr 08, 2013 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I have a st622 ariens walk behind What size is the string I should be using.
Your trimmer line is 18" in Length (46cm)
5/32" diameter (0.40cm). I'll give you a link to your owners manual that you can download and I hope that the link works. You may have to give some info to log into the site in order to get it; not sure, as I use the site quite often to download manuals and only had to do that the first time.
http://dl.owneriq.net/3/3f858f4f-0b60-49b5-a6f8-ec4a7a994de4.pdf
Best of luck to you.
James
Aug 11, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
May 04, 2009 | Garden
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
