Question about Kenmore HE2 Plus Front Load Washer
Why won't it start?
Door stays locked but no error codes displayed. have unplugged several times and have manually released the door. every time the door locks but won't start. after pressing power button, add a garment light flashes while door stays locked
SOURCE:
  • 100 Answers
SOURCE: He3 Won't start - lock door or start water flow, although dispay works with no error
The door switch is damaged and needs to be replaced.
Posted on Oct 30, 2007
cpldw48
  • 226 Answers
SOURCE: Kenmore He 2 Plus washer door is locked and unable to open
unplug the washer an the door will open
Posted on Apr 25, 2010
SOURCE: kenmore elite he3 - door lock
fdl error code on kenmore elite he4 washer. wont start after selecting wash cycle
Posted on May 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: add garment light stays on after garments are added
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
  • 21 Answers
SOURCE: My Kenmore HE2Plus Model 110.47532602 shows F28.
it is for a serial communication error. usually means you have a problem with one or more of the control boards in the washer. hopefully your under and extended wtty with sears. after you get your problem fixed get a surge protector for your washer. its operated by several boards that act like a computer and noone in their rite mind would use a computer with out a surge protector.
Posted on Feb 19, 2011
Testimonial: "I figured it was CCU &/or MCU- your answer confirms it. Not under warranty-guess I'll buy another washer def NOT Sears! Too many neg reviews. Thks!!"
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
Installed new door lock still have e27 error code
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
You can manually release the latch by removing the lower panel (Torx fasteners, I think) and finding a wire lanyard that releases the latch. However, I had read that there was a diagnostic code that could be used to reset the latch solenoid via the control panel.
There is no service manual available on line, as far as I can tell.
Here is what worked...
1. Set the knob to off.
2. Hold down both the Spin Selector button and the Allergy Rinse button simultaneously.
3. While holding these two buttons down, rotate the knob one click to the left, to the "cold" position.
4. At that point, the display will show a diagnostic code and the unit will enter a self-test mode. In my case, the solenoid latch started clicking repeatedly. I pressed the Spin Selector button once or twice, which resulted in the display of new codes and then the release of the latch.
Oct 15, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
What is error dL f
Doorlock error.
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
I have a service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
Continue to receive DL (Door/Lid cannot lock) error message. Pause/cancel and then start don't work. I have made sure nothing is blocking the door. I have unplugged and plugged back in. Continue...
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
Jan 01, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
When i started the machine, it went to start, then clicked and gave me a f dl error message. the door is now locked and will not even allow me to get clothes out. i have unplugged the machine several...
Unplug the unit, remove the lower access panel (front of the machine) reach up and find the small lock release tab and pull downward to release the lock manually. remove your clothing. This is usually do to a door switch failure. Replace the door switch. It may also be a wire coming loose or making intermittent contact. Hope this helps
Oct 22, 2010 | Whirlpool Washing Machines
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 error on kenmore he2plus washmachine. Door locks. Due to no spinning and water remaining in the machine? I run the rinse/drain&spin program (15 minutes) several times. it stays at 15min remaining...
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Mar 23, 2010 | Kenmore HE2 Plus Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LG Washer dryer error dE
Unplug the machine.
Plug back in (maybe 10 seconds later).
Mine had several dE messages. Unpluged, waited 10 seconds, when pluged back in, it remembered which cycle and parameters I had it on, then locked the door and continued with no problem.
Mar 17, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
106 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
