Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Lamp problem I had a relatively new lamp installed.  I then took care to be sure that I didn't leave it on for no good reason.  Therefore there are low hours on the lamp.  The red light came on.  No screen.  I got a new lamp. Switched out the lamp and it does the same thing.
  • LivingLoud Dec 19, 2007
    mine has done the same thing I bought a new lamp and it did it again took lamp back they said the lamp was fine so whats wrong with it?
  • 1,153 Answers
Do self test diagnosis first
Posted on Dec 16, 2007
My dimension 8400 freezes. It won't load windows. It freezes at the windows logo.
Welcome to Fixya!
What you need to do and I am sure you have done so already is leave it to load. Give it time as it may be having difficulty processing the operating system.
It is possible that the Microsoft Widows Installation has become currupted, it will therefore need to be repaired with the aid of the Microsoft Windows installation CD.
Contact a computer technician to repair the installation if need be, a repair would simply correct any errors detected by the application therefore keeping your data safe. Run an anto-virus scan to be sure that there are no viruses running.
Take care!
Oct 04, 2011 | Dell Dimension 8400 PC Desktop
How to fix GE cooktop error code F116
First, i tried turning on/off power with no luck. if you get this code you will probably just need to replace the LF burner, which is pretty easy to do. i researched and found GE OEM parts from appliance zone. info is below: Items
1 Stove / Oven / Range Radiant Element Lf - WB30T10080 (OEM) @ $170.67 = $170.67
Sub-Total: $170.67
Shipping: $6.95 Standard Shipping (6.95) USD Total: $177.62
Once i received then new burner i just replaced it and all is working fine, no error code!
First i turned off all power and removed my cooktop from my counter and unscrewed the sheet metal shroud on the bottom, only remove the screws around the perimeter of shroud closets to glass, they are small black Phillips screws, like 15 screws total. i didn't disconnect any wires from the unit to junction box, you should be able to leave all that alone if you have a long enough connection. i made the mistake of leaving the cooktop upside down when removing the metal shroud, don't do this. there are springs on posts that keep the burners tight to the glass and will fall out (if up side down). leave the cooktop right side up and just lift off the glass once you remove all screws, when lifting the glass off, there is one plug at the circuit board attached to glass that you will need to unplug to completely remove the glass and set aside. you will see the 4 burners, i took a picture of the unit with glass removed to make sure i could reference any wires when i was re-installing new burner. i unplugged all wires to LF burner and unplugged the harness from the circuit board. once i removed old burner i noticed the new burner doesn't include the 2 tabs you need. i removed them from the old burner and made sure to install them in the same location on the new burner. I than plugged in all wires and harness back into the unit and set burner on posts with springs. carefully replace glass and don't forget to plug the glass top circuit board back into the unit circuit board. re-attach metal shroud and screws, drop in and done! there are instructions to re-calibrate the new burner which is probably a good idea, i didn't and it is working just fine! good luck
on Nov 16, 2013 | GE 30 in.JP950 Electric Cooktop
I put a new lamp in my hitachi 50v720 tv. The light keeps blinking and the power will not come on
If it was blinking like it was, it's probably either a bad lamp or a faulty install. Try re-installing the housing of the lamp in the T.V. if you're sure you didn't over tighten or under tighten the screws on the lamp. These are all simple things to check before you send back the potentially bad lamp.
Jun 17, 2011 | Hitachi 50V720 Television
Lamp light is flashing
Most likly a bad lamp. A-1606-034-BM2991690 Complete , you will find 2 thumb screws on rear of set, remove the front panel, remove lamp install new one in reverse order. BE careful to not bent the door switch.
Please leave feedback
Feb 21, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Honda Accord 1991, the car can't pass the smog check. what do you think is the problem?
Probably the old catalytic converter. Could also need a good tune up with new spark plugs and a fresh air filter. You can buy a universal catalytic converter relatively cheap at a good auto parts store. Take it to a good muffler shop and have it installed. Shouldn't be more than $60.00 labor. Be sure to keep the old converter. You can recycle it and recoup some of yo money. If you leave it with the muffler shop, they will recycle it and get that money, plus what they charged to install the new one. With the new plugs and air filter, the fuel will burn more efficiently. And the new catalytic converter will take care of the rest. You should be able to pass the smog test, and get better gas mileage and performance.
Feb 17, 2011 | 1991 Honda Accord
How do I change my projection lamp for my Sony Wega KDF 50E2000.
You have to get lamp fully assembled for easy replacement. That mean lamp should be purchased already installed in black plastic housing.
If you stand behind of your TV set on the left hand side (actual side) of your TV you will locate lamp door cover with latch on the top of it. Just push the latch down and remove cover. Deeper inside you will locate black plastic lamp door with handle that you have to rotate 1/8 of the turn counter-clockwise to open it up ( like a submarine style thing). Pull it out and next thing that you will discover - lamp assembly itself. Put your index finger inside of the ring-looking latch, pull it up and out. You have lamp removed now. Extremely carefully install new lamp in same order making sure that new lamp is ALL WAY IN (there is safety switch that sense if lamp is not properly in) and install the door making sure it is ALL WAY IN and LOCKED (there is another safety switch that sense it). If any of the switches will not sense proper installation TV WILL NOT turn on.
You can turn TV on to check if it is working. Last thing to do - reinstall lamp door cover.
Dec 01, 2010 | Sony KDF-50E2000 50" HDTV
The model you listed is a rear projection DLP set that uses a lamp and not a CRT. The part number for the lamp is 6912B22007A and is just the bulb itself. Meaning when your go to replace it you have to remove the old lamp from its housing and carefully install the new bulb in the old housing. You will want to use latex gloves so you don't leave fingerprints on the new lamp as it will shorten the life if it.
Sep 08, 2010 | LG RU-44SZ63D Television
Shutting off then on continuously, w/ green light on
I pulled the lamp, and blew the dust off of the top. TV is back to working great!
Oct 28, 2008 | Sony KDF-E55A20 55 in. LCD Television
97 transmission pump
Just remove the front pump bolts, you will need new O ring seals, DON'T USE THE OLD ONES OVER, the pump will be hard to remove, but it will come out, have the trans pointed up or all the fluid will gush out on the floor, when you install the new O rings use good old Vasoline petroleum jelly ( heap generic works fine also) to lube the O rings, be very careful putting the pump back in or you will tear the new O ring seal and all you did will be for nothing, really lay the Vasoline on there, the more the merrier!
Oct 22, 2008 | 1997 Chevrolet Blazer
Replacement Instructions
it's a simple switch out, first make sure your set is unplugged, open the panel concealing the lamp, unscrew the door, unscrew the lamp, pull it out straight towards you it is attached like an outlet plug, carefully switch it with the new one be sure not to touch the lens, screw in tightly replace the compartment door then the panel and your done....good luck }:)
Jul 04, 2008 | Sony LAMP BLOCK XL2100U Projector Lamp
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
