Question about Aquabot Robotic Pool Cleaner
I just bought replacement scrubbing brushes for my aquabot. The new ones are different. How do I install the new style cleaning brushes?
    Problem Solver:
  • 15 Answers
Http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html my give useful instrucyions, or, if you are near Phoenix Az I'll be glad to help! S. Christian dansker01@msn.com
Posted on Aug 22, 2009
How do I clean my Merrill mesh Mocs? I have blue, red and tan mesh Mocs and they sometimes get stains. Can I wash them or scrub them? Thanks!
As my experience for my shoes, I did scrub them by the foot brush with clothes detergent, they are super clean after washed and dried by the sun. But your mesh mocs maybe can't be scrubs by brush so I think the better solution is use a tower and scrub them
Sep 09, 2017 | Clothing Accessories
Tip
How to Clean a Tile Floor and Grout when nothing else seems to work.
What you need is Cleaning Paste, a Scrub Brush, an Enviro Cloth and water. The picture shows a before and after. After years of mopping the floor with the traditional cleaning products, dirt had discolored both the tile and grout. I was down to needing to decide to start over by replacing the floor, or give it one last try. I had seen and heard about this product from a friend who I purchased the products from but I didn't really know if it was hype or truly something new that would work.
It restored my kitchen floor to like new! I never thought it would work but for the $50 it would cost in products if it worked, I wouldn't have to pay Thousands to put in a new floor.
I simply scrubbed on the cleaning paste using water and a scrub brush. Let if sit for a minute or two and wiped up the floor with my EnviroCloth. It took a little bit of time to do the whole kitchen but for me, it was definitely worth it!
I purchased these products from www.ChristineFrey.Norwex.biz
The Cleaning Paste has more then just floor cleaning possibilities.
on Jan 31, 2015 | Home
Starts but stalls every few minutes
Clean your carburetor with carb clean and scrub with a tooth brush, lots of YouTube videos for instructions, and clean or replace your air filter.
Jan 23, 2016 | Garden
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Maytag dryer model #PYE2200AYW how to remove lint compartment once I removed the screws in the front
Instructions
Things You'll Need:
Nylon scrub brush Liquid detergent Vacuum
1.Remove the lint screen, which usually is located in the front of a Maytag dryer. Gently pull it up and out, and remove the lint with your fingers.
2. Use hot water and wet both sides of the lint screen. Use a nylon scrubbing brush and a little bit of liquid dish soap or laundry detergent to scrub the screen clean of lint and fabric softener buildup. Rinse both sides thoroughly with hot water. Towel dry and replace the lint screen when dry. Maytag states that owners should do this every six months.
3.Clean the exhaust every two years, as recommended by Maytag. Whoever installed your dryer had to install the exhaust vent. Unplug your dyer and unscrew the vent from the back of the dryer. Use a vacuum attachment or your hands to remove any clogged lint and replace. You may need to do the same thing to the other end that is attached to the wall.
4.Clean the dryer cabinet. According to Maytag, a professional should remove lint from the dryer cabinet every two years. This may be a good time to have him clean out the vents as well, rather than doing it yourself, if preferred.
5.Clean your lint screen on a regular basis. Maytag states that you should clean the lint screen with your fingers before using the dryer each time. Be sure to replace it all the way so it can work properly.
Mar 10, 2011 | Maytag Dryers
How do you change a positve battery cable on a 1998 dodge avenger car?
First a little more clarification would be helpful in, Why do you think the cable needs replaced? If the cable is corroded at terminal connection a new connection fitting is much more simpler than cable replacement. Nonetheless, remove the negative battery cable first, then the positive. (1)Clean the corroded area's with baking soda and water mixture (you should wear eye and hand protection- battery acid will eat through clothing in a matter of minutes).Scrub gently with nylon brush -using a wire brush can cause sparks and may cause a fire from hydrogen gas escaping form battery. Flush with clean water and your ready to start the next process. (2)Assuming you will adding a new terminal connection fitting - cut off bad fitting with wire cutters or hack saw, skin back wire about ONE inch and install new cable fitting.(3) install / reconnect battery. (4) Your cars computer will be cleared of all learned shifting patterns and other feedback information. It will revert back to factory preprogrammed settings. Average cost of replacement cable clamp $3.50. New cable cost to starter +$30.00
Happy motoring.
Jan 03, 2011 | 1998 Dodge Avenger
Faucet is hard to pull on both in lavatory and shower valve.
need to replace the cartridge. there really is no "fix" other than that.
use a good non silicone grease, and clean out the hole where the cartridge goes using a wire brush. you don't have to scrub, just a few times back and forth till it looks clean.
grease the new cartridge before you install. doesn't need much, just a thin coating
Aug 12, 2010 | Moen 1 Handle LavatoryWith Drain Assembly...
Brush dosen't move
Brushes not moving are usually caused by the turbine bearing seized. This job requires the turbine to be removed, completely dissassembled, cleaned new bearings and then re assembled and installed. The tank is another part, if your tank does in fact need replacement then the normal cost is between 45-60 dollars. Even if he completely replcaed the turbine, those cost about 35-45 dollars. I do know that the new tank style (all clear) is made much better than the original (2 color). This model is a good one. you are getting to the 50% of cost for a new model. if you get this one fixed make sure they install a gasket under the turbine, to prevent further issues.
Oct 18, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Aquabot T2 moving in circle
The T2 has one set of belts and a single drive motor. Since one side must be rotating to be moving in a circle, we can then assume that the motor and belts are not the issue here. The two halves of the brushes are connected by a mechanism that allows them to turn independently of the other half. They can rotate about 3 times before they “lock” and act as it were one (not split) brush. This “slippage” is how the cleaner turns. Make sure that they do lock by manually rotating one side. If not, you will need new brush/wheel tubes.
A parts diagram can be found here:
Aquabot Parts and Repair
Jan 09, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Aquabot Robotic Pool Cleaner Logo
173 people viewed this question
Top Aquabot Pool & Spa Experts
Ian Summerfield
Ian Summerfield
David Spradling
David Spradling
Robco Water
Robco Water
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
