Question about Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive
PC Doctor error code Failed SMART Test Error Code HD521-2W
    Scholar:
  • 81 Answers
This is in an HP PC? This error (like most SMART errors) is indicative that your disk is on its way out. Your best bet is to buy a new disk quickly, and get important information off this one! SMART errors are usually fairly accurate, though occasionally disks go on for years.
(SMART = System Monitoring And Reporting Technology)
Posted on Jul 12, 2009
Spindle test Failed (Error code: WCD44-RVH)
Spindle usually refers to the spinning axis of the carbon disks or the platters. The disks are likely not spinning and a drive replacement is required.
Jun 25, 2014 | Dell Inspiron 530 Desktop Computer
What does Error Code: HD521-2W mean and how to fix it
http://h30434.www3.hp.com/t5/Desktop-Hardware/SMART-Short-Self-Test-Failed-Error-Code-HD521-2W/td-p/1181885
Nov 09, 2013 | Samsung SP2004C 200GB 7200RPM 3.5in 8MB...
Error code 0147 spindle test failed
The error you received (2000:0147) indicates the drive has failed. It cannot be fixed. You need to replace the drive.
May 27, 2012 | Dell Studio Xps 8100 Desktop Computer
The product is compaqe presario CQ32701X desktop PC and the problem is..... window is not starting normally. when we did pc diagnosis (F9). while testing ST3500418AS (9VM79Z6S), drive, showing error...
If you are getting errors from the hard drive diagnosis, the solution is--replace the hard drive. Don't mess with it. You can install the defective hard drive as a second drive and possibly lift data from it. Keep messing with it and you may lose more data.
Jul 27, 2011 | Computers & Internet
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
GOT ERROR CODE RW529-2W what does that mean
Normally error codes are manufacturer specific...and about the only references you will find to them is from software designed by third party venders and may or may not be supportive of your hardware. In most cases as with yours the data represents what tests were being done and that there was an error during that test but not what the actuall error was. for instance: CD523-7W..... the CD523-7 means that it was a funnel seek test on a CD/rom drive....the w is what/where the error was and is software specific...meaning that the "W" code is determined by the software that performed the test and may not actually be the specific error for your hardware.... CD523-9W. refers to a random seek error RW529-1W. refers to an ATAPI rewritable drive All in all the code that you have supplied refers to a failed head allignment (funnel test) and a failed read and write test(seek) on an ATAPI drive. simply said that if the heads are out of allignment then the optics certainly can't read or write correctly either. Now understand that a true test cannot be made while windows is running and so the tests should have been performed in a DOS environment...also there must be a readable CD inserted....so may not be accurate at all. If you were using PC-doctor in DOS mode then holding down the space bar may give up a tad bit more information. Hope that helps you!
Jun 16, 2011 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
My Dell Inspiron 6000 has Samsung Model MP0603H hard drive. The computer was working fine till this morning when it would not boot. I ran diagnostic using the Dell CD and the results stated: Error Code...
Those codes all apply to the hard drive itself..
Replacing the hard drive is all you should have to do.
Below is a link to a brand new hard drive that will work in your Inspiron 6000
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=350216497944&rvr_id=119484484159&crlp=1_263602_263622&UA=%3F*F%3F&GUID=1ca6610412a0a0aad456d986fffd8c0c&itemid=350216497944&ff4=263602_263622
Aug 03, 2010 | Samsung ( MP0603H) 60 GB Hard Drive
Samsung SpinPoint P120 SP2504C 250 GB SATA II Hard Drive Logo
1,514 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
