Question about E-Machines T6216 (827103077834) PC Desktop
The cd drive in my emachines t6216 doesnt work
The cd drive in my emachines t6216 says connect burner and restart computer but weve tried everything how do i fix it????
    Sergeant:
  • 400 Answers
First open the case and check if the power connector ,and other cables are still connected to the drive. if they are there disconnect the power cable ( while the computer is running and Plug and Play should notice it). then run add new hardware app to see if the system did recognize it, then check the device manager if its there. reinstall the drivers for the burner drive and run program ,and see if it runs ok, if not the drive is bad and will need to be replaced.
Posted on Jul 12, 2009
My T6216 Emachine stopped working. None of the
Even if those things power up doesn't mean your PSU is still good.
In particular the PSU in eMachines are known to be cheap/bad and one of the first things to go out.
If you have access to one try another ATX power supply.
You don't have to remove the old one just to test.
1) Unplug the existing PSU power cable from the back.
2) Remove all it's connections (MB, drives, etc).
3) Plug the other PSU in with just the two MB connections (the main, and 12v one), skipping any drives for now.
It's probably ok if the test one is not touching, but I like to put the PC on the side with the test PSU setting on top where the original one is making sure it has good contact with the case to make sure it's grounded.
4) Now plug the AC into the test PSU and power it up.
If it still dosn't power up it's probably MB, or CPU.
You could also unplug it again (you always want to unplug the PSU when doing anything, the power is always on), and try removing any add on cards (like your wireless card), and try again.
If it does power up (you get a POST screen), unplug PSU again, now plug-in drives, then AC back and see if it will boot up.
Jul 20, 2010 | E-Machines T6216 (827103077834) PC Desktop
Emachine el1200-07w model - optical cd/dvd burner drive is no longer working, as if the computer no longer recognizes the drive at all? Any way to fix this?
Try pushing the drive in the notebook and if the
drive exists outside the notebook, try pushing all the leads in the drive.
The first on worked with mine.
Jan 16, 2010 | E-Machines emachines (emachinees) CD-ROM...
Windows media player keeps asking to connect a burner and restart pc so I can't burn CD's
Make sure in the windows media player options you have selected the corect drive as your burner. hope this helps in some way
Dec 04, 2009 | eMachines W3653 Refurbished Desktop...
Connect burner and restart Windows Media Player
Run REGEDIT
Select {4D36E965-E325-11CE-BFC1-08002BE10318} at the end of the following path:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
In right pane select UpperFilters do an Edit/Delete
In right pane select LowerFilters do an Edit/Delete
Exit REGEDIT
Right click MY COMPUTER
Properties
Hardware
Device Manager
Uninstall CD/DVD player/burner
Restart the machine and it will find and reinstall the burner
NOTE: if you’re uncomfortable deleting registry entries, rename them (e.g., w/ “.SAV” extension)
Jun 06, 2009 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
Sound card not installed
if you cant find the cd for the tv tuner card just take out the card and find the model number ands google it and search for the drivers from the manufature website
Feb 13, 2009 | E-Machines T6216 (827103077834) PC Desktop
T6216 CAN'T USE CD BURNER ERROR MESSAGES INDICATES NO CD DRIVE
Sounds like your CD drive is gone. Try inserting a program cd and see if it reads it. You can also switch the cable attached to the cd drive. Make sure you get a power light on the cd drive when you start the PC, if not you can try a different power connector from the power supply. Hope this helps.
Nov 06, 2008 | E-Machines eMachines Desktop PC
CD Burner doesnt see a Disc is in already
failure my friend. try to restart your computer, this way, after restarting, your drive will recognize that a cd is in.
if it still doesnt recognize that a cd is in, try updating the firmware of your drive and clean the lenms of your cdrom too.
Mar 22, 2008 | TDK ( ue401248bx) CD-RW Burner
Not working
Is the drive connected propperly ?
look at the jumper settings if its IDE
if it is connected propperly and still doesnt show up
( verify its showing up in My COMPUTER)
try it on anoter PC to see if it works.
Just cause its new doesnt mean it works
If it works and you did connect it propperly the let me know
IS IT READING ANYTHING ?
Is IT SHOWING UP IN YOUR DEVICE MANGER?
Click START, (right Click) my computer, select properties then device manager, it shoud show up in DVD/CD-ROM drives
if it doesnt then right click on anything and scan for hardware changes. If it doesnt show up then it isnt connected propperly.
Oct 13, 2007 | LG GSA-E10L (8801031212552) DVD±RW Dual...
E-Machines T6216 (827103077834) PC Desktop Logo
178 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
