Question about HP PSC 1610 All-In-One InkJet Printer
Error code wont initialize
Error 0x031e4dd6798:lib_barracud I have tried to disconnect, when I reconnect sometimes it won't even power on. I've tried with different ink cartridges, I've even cleaned it. Any ideas?
  • 304 Answers
Re: error code wont initialize
The next step is to uninstall the driver and software for the printer and do a fresh install of the software. It sounds to me like your drivers have been corrupted. If this is the case reinstallation of the software and drivers will solve your problem.
If this does not work here is the tech support line for Your product: 1-800-474-6836
I hope this fixes your problem, Please do not forget to rate me if it does.
Thank You
Posted on Jul 18, 2008
0 characters
3 Points
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
first is your printer blocked or jammed
second do your ink cartridges have ink in them
third go to help in hp printer file check there
let me know please
Jul 18, 2008 | HP PSC 1610 All-In-One InkJet Printer
50.2 fuser error on HP printer 2840. Received this error, change the toner Q3964A for new one but still having same error code. Tried turning off and waiting 10 minutes and trying again but still same...
  1. Turn off the device, and then disconnect the power cord.
  2. Remove the fuser and then wait at least 20 minutes. To do so, complete the following step
  3. Turn off the device, and then disconnect the power cable.
  4. Rotate the locks on the fuser to the unlocked position, On the rear of the printer.
Grasp the fuser handle and pull the fuser assembly from the device, .
CAUTION: The parts on the internal surface of the fuser are very hot. To avoid being burned, do not touch those parts.
Using both hands, slowly and steadily remove any print media from inside the device. Then, carefully reinsert the fuser and secure the locks.
  1. Reconnect the power cable, and then turn on the device.
  2. Wait for the device to initialize.
  3. If the error persists, replace the fuser assembly.
Jul 07, 2011 | HP LaserJet 2840 Printer
I get the Error Code Oxc18a0201. How do I fix it? Carl
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
Feb 17, 2011 | HP Photosmart 3310 Printer
Printer wont print
this is a complicated error message so if the printer is in warranty immidiately contact hp or even if the printer is in warranty call hp you will get the support if you bought geniun ink cartridges how ever you can once try the following step Ink system failure is generally followed by an 0xc0...... error code and the trouble shooting is different for different error code so please follow this simple trouble shooting and even if the printer is not working then please specify the exact error code
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
is still you face the same problem please rerply us with the exact error code
Aug 28, 2009 | HP Photosmart C6180 All-In-One InkJet...
Km-2030 Checksum error f1
my copier is displaying error code 100, whats the problem km 2030
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Error msg below
its the main board error.that needs to be will be very costly .
sometimes unplugging the printer for sometime and then replugging it helps.u can try that before taking any descesion.
Nov 12, 2008 | HP PSC 1610 All-In-One InkJet Printer
52 Scanner error
52 scanner error means yoy got got an error with the scan assy, it could be many problems. If it not helps with turn off /turn on, try reset the printer. Turn off power press and hold * and #, turn on power, wait 20 sec and release the buttons. If printer not goes to ready, disconnect power cord when printer initialize and turn off power switch. reconnect power cord and turn on power switch. If you get the printer to ready state, upgrade firmware.
Oct 15, 2008 | HP LaserJet 2840 Printer
Error: 0xb9dlbf0a
These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Jul 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Error: 0x07a74dd61959:lib-barracu
Its a Fimware Error.
Try a Hardware Reset.
-Switch the Printer on
-unplug the powerkable
-press "#" and "6" and plug in the Powerkable.
when the Display shows Initialising or Semi-Full-Reset. release the "#" and the"6".
sometime this is working
Jul 14, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
314 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
