Question about Dishwashers
Water leaking from bottom of Water inlet. How does the inlet come apart? Is there a replacement seal?
  • 1 more comment
  • chris_rees Jul 12, 2009
    The leak is on the side of the dishwasher where the water goes throught the side of the diswasher (water inlet opening - discription from the users guide). On the outside the is a square block (5in X 5in) that mounts to the side with a hose comming from the valve under the left front corner. On the inside is a 3in round louvered piece. There seems to be a rubber gasket between the two inside and outside halves. Water stains are obvious from the bottom of this piece. How do these two pieces come apart. I think the seal should be replaced and or the conection tightened.
    Thanks
    C
    Thanks
    C
    KitchenAid KUDS25SH
    Thanks
    C
  • 3,037 Answers
You are right, the seal has probably gone bad and needs to be replaced. Can you post the make and model of the washer in question so that I can help you find a replacement gasket and give you the right information.
Benjamin
Posted on Jul 12, 2009
  • Benjamin Patri
    Benjamin Patri Jul 12, 2009
    Sounds like you just need to unscrew the copper pipe from the washer and wrap some Teflon or Plumbers tape in the same direction as the threads which is all that is needed. You only need to wrap it one layer thick for a water tight seal If the copper pipe itself needs to be replaced, you can get more pipe from a local hardware store but the tape probably just needs to be replaced. You can get more of the tape from the hardware store too, it will be under $1 for a roll.
  • Benjamin Patri
    http://www.kitchenaid.com/assets/pdfs/pr...
    page 19 should show the fittings and how they go together for reference
    Genius:
  • 1,689 Answers
Hi Chris,
thanks for using fixya
the issue is not usually the inlet seal but the inlet valve. the repair will depend on what is the brand of your washer as well as the model.
below are general instructions on how to repair / replace your water inlet valve.
1.
Step 1
Unplug your dishwasher for safety reasons, and double check that it is no longer connected to its power source. Depending on your dishwasher, you may have to turn off its power from the circuit breaker or remove a fuse. Shut off your water valve and turn off the water supply to your machine. You may have a hose that runs from the faucet.
2.
Step 2
Find the panel underneath your dishwasher, often referred to as the kickplate panel. Some panels need to be unscrewed from their position; others fold down because they are hinged to the machine.
3.
Step 3
Locate your inlet valve. In most machines, it is located in the left or right corner of the panel and should be visible to you. Your inlet water valve will have hoses connected to it--one that takes water to the machine and another that takes water away. This is a good time to check that your hoses are in good condition, not corroded or kinked. Take the hoses off the dishwasher intake valve. You should probably place a container underneath before disconnecting in case there is water left in the hoses.
4.
Step 4
Disconnect the wires from the inlet valve. Write down where the wires go so there are no problems reconnecting later. Not using the wires but the connectors instead, disconnect the wires. You may have to use pliers to do this.
5.
Step 5
Unscrew the inlet valve, remove it, and save the screws. Now, place your new water inlet valve where the old one used to be, and screw it in place with the old screws.
6.
Step 6
Replace the hoses and wires. You may want to turn on the water, and check if the hoses are secured in place and not leaking. Put panel back in place and turn on the power to the dishwasher.
for parts: http://www.easyapplianceparts.com/repair.aspx?appliance=dishwasher&part=dishwasher-wont-fill
For a video on replacing dishwasher parts: http://www.ehow.com/how_2072961_replace-dishwashers-water-inlet-valve.html
Hope this helps.
regards,
voodoo
  • marlon john madrid
    marlon john madrid Jul 12, 2009
    hi chris,
    if that is the case then yes, same video will show you the seal replacement
Both drawers leak in the front
If your dishwasher leaks, check these:
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Apr 01, 2010 | Dishwashers
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Danby DDW396: pump leaks when in use.
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 11, 2009 | Danby 22 in. DDW396 Free-standing...
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Leaking water from front of door
I replaced the seal part # 154576501. The notch is on the right facing the dishwasher. Just pull it out and insert the new one.
I've fought this problem for over a year, thinking it was an adjustment. I am now running it through the third cycle and I am positive it fixed my leak. Also, while you have the cover off, check and trim the tie-wrap around the wire loom. Mine was interfereing with the seal, but the seal was also slightly distorted allowing the splash to come underneath.
BnoGno
Nov 16, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher leaks water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Nov 03, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Water seeping in dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
