2007 Chevrolet Chevrolet Equinox LT Logo
Delrio Fernandes Posted on Sep 12, 2015
Car has no power absolutely opened the door with the key tried starting the car no sound no light now key is stuck in
Night Darkfold
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 11 Answers
  • Posted on Nov 18, 2015
Night Darkfold
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
11
Questions
0
Helped
5483
Points
27
Your key is stuck because your battery is dead, try hooking up a battery charger to it, remember to pay attention to the proper battery terminals so you do not damage your battery or your electrical system.
The key is likely stuck due to a solenoid that is designed to keep you from removing the key if the vehicle is not in park, when the battery is dead the car does not know it is in park and therefore locks the ignition tumbler from returning all the way off.
How To Connect Battery Charger
2 Related Answers
Anonymous
  • 64 Answers
  • Posted on Dec 04, 2008
SOURCE: Car will not start no power or lights work on the inside
that acts like the starter solenoid has a bad connection or has gone bad. first remove the starter , and see if there is any corrosion or burnt areas . also while you have it out , take it to auto zone . they will be able to test it for you for free .
john h
  • 29494 Answers
  • Posted on Oct 26, 2009
SOURCE: We just purchased a 2006 Chevy Cobalt. Two days
could be in security lock down check key fob batteries if batteries good check with dealer if key has electronic chip in it key may be problem
2005 Altima....key stuck in ignition
try the main fuse coming from battery to fuse box under the hood sounds like it popped.
I assume the factory alarm was somehow bypassed when they installed the remote start is there a way I can make the factory alarm work when the doors are opened without key,?
To arm content theft alarm.
1. Open the door.
2. Lock the door with the power door lock switch or
the remote keyless entry transmitter. The
SECURITY light should flash.
3. Close all doors. The SECURITY light should go off
after approximately 30 seconds. The alarm is not
armed until the SECURITY light goes off.
If a locked door is opened without the key or the remote keyless entry transmitter, the alarm will go off. The headlamps and parking lamps will flash for two minutes, and the horn will sound for 30 seconds, then will turn off to save the battery power.
3answers
My battery died. After trying to start my car the key is now stuck in ignition, shifter stuck in park, no brake lights. I charged the battery and only get the cluster lights.
Hi there all the things you explain are and need power to operate, make sure your battery has 12.6 volts or more and try again , if your battery doesn't have that voltage then you will need a new battery, hope this helps
Honda accord power door lock
Try pushing in on the inside door handle while you try opening from the outside with your key. Sounds like you have a lock rod inside the door hanging up the operation you are trying to do or someone tried slim jiming your car
I left my keys in the ignition for a couple hours & when I came back to my 2001 ford taurus and took them out my alarm went off.. I couldn't start my car it was dead.. So not I stuck with a dead car &...
try this it may work put key in ignition and turn to number 2 ( lights on dash) press the fob button on the key. doors should lock, then turn back off to 0, then press the fob button again the doors should open then try to start engine. if all works again but the alarm keeps going off randomly, the power sounder battery may be flat, it can be charged when the system is working again. but sometimes it can get damaged. and it may need to be changed. as I dont know what the sound is coming from under you hood Im thinking it could be this.
IS 200 wont start, no dash lights, no radio,
You should have power to the dash if the key switch is working.
The main fuse would kill everything in the car.
Depending on how it happened, I would check the fuses and then check for voltage at the key switch.
1helpful
I replaced my remote battery now car won't start or close doors or open doors. with spare key .i can only start the the car by taking the spare key out of the remote putting it into the ignition and...
If you need to be that close to the car to start , you still have a bad to low battery.,You notice that you had to get close to it.If you are sure absolutly have a new battery enter the car put key in regular position leave key in for 2 minutes cylce it off there see if it will start back in it normal range.
Battery is fully charged lights come on but power to dash and turning the key wont turn the engine over. not clicks no sound car intidacator lights come on along with the ding ding when the door is open....
Probably your security system or the safety interlock. If the security light is not on, try giggling the shifter or starting in neutral.
Please see my tip at http://www.fixya.com/cars/r6222268-engine_doesnt_crank_turn_over . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
1helpful
2answers
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
