Question about Dell Latitude D600 Notebook
My wireless connects to the internet but i cannot ping or recive packets
  • 390 Answers
Hi
there are a few steps involved
1. check to see the ip address provided to you by the ISP and group your ip address range to the same range
2. check to see if you require any DNS server addresses
3. check to see when the router is connected at the internet port from the modem then is it having signal at the port numbered 1 only or is there no signal at all ports 1-4
4. if there is signal at port1 but not on other ports then instead of connectng the cable from the modem at the INTERNET port connect it to port1 and it will be distributed to all the ports 2-3 also there will be wireless connectivity too
cheers
Pls rate if this was any help
Posted on Jul 12, 2009
SOURCE:
I have a dell optiplex gx520,it is hooked up to wireless connection and it's showing that the signal is good,but IE won't let us view webpage......
can you check if have a valild IP address?
1. Start > RUN > type in "cmd"
2. On the command prompt windows (black DOS window),
> type "ipconfig" > hit Enter
> you should have a valid IP address (something like 192.168.x.x)
• if yes, then try to ping a website
• if no, (you should see somthing like 169.254.x.x), check your wireless settings again.
**good signal doesnt mean that you are connected, it could be a conflict with wireless encryptions too..**
3. to perform PING
> on the CMD screen (back DOS based window), type "ping (space) google.com"
> you should see ping statistics, something like "packets sent=4 received=4 lost=0"
• if 0% lost > your connected to the internet
• if 100% lost > you have no connection
> again check your wireless again
4. If you can Ping and you can't still view webpages using IE here's what I suggest
• Optimize your browser
-delete temporary internet files and cookies
4a.1 Open Internet Explorer
4a.2 Click "Tools" (the icon that looks ike a cogwheel / gear; usually at the upper right corner of internet explorer)
4a.3 Click "Internet Options"
4a.3 Click "Delete" under the General Tab Screen
4a.4 Restart Internet Explorer
• Reset Internet Explorer to factory settings
4b.1 Open Internet Explorer
4b.2 Click "Tools" (the icon that looks ike a cogwheel / gear; usually at the upper right corner of internet explorer)
4b.3 Click "Internet Options"
4b.4 Click on the "Advanced" tab
4b.5 Click on "RESET"
4b.6 Restart Internet Explorer
Hopes this Helps
Aug 09, 2011 | Computers & Internet
I bought a DLink DIR 600 wireless router and want to connect ONLY two PC to it. One is wireless and one is wired. No internet connection to www required. The wireless PC OS is Fedora 14, the wired PC...
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Jan 24, 2011 | D-Link DIR-600 Router
My router is on but it seems so slow. i keep getting randomly disconnected, the connection is terrible and even when i turn it off for 30 seconds and on again it stills acts up, any ideas?
ping your router with a packet length strength. To do the ping test, go to Start-Run and type CMD and hit enter. Then, in the Command Prompt Window type in the following
ping 192.168.0.1 -l 30000 9
I suppose the 192.168.0.1 will be the default gateway of your router. To check which is the default gateway of your router you can double click the connection icon on your PC, and click the Support tab. You'll see the degault gateway IP third on the list.
Now, if it pings back all three times with times below 100ms then ok. If it doesnt then reduce the ping length to 20000, if again you have losses then reduce it again to 10000. If the ping loses packets and response is slow you'll probably need a new power cord.
If the pinging is ok at 30k then you'll probably need to change the LAN cable that leads from your internet connection onto the wifi router.
To verify this, run this command
ping google.com -l 10000 and see if you have any losses. If you do have losses, then do a ping like this
ping google.com -l 32000 if you again have losses in the ping then you'll need to change your LAN cable because the 32kb packet is almost a standard size of packets and it should have no problems to get through the router, unless the LAN cable is bad.
Hope this helps. Please vote a Thumbs Up if you found this useful and informative.
Jan 18, 2011 | NetGear WGR614 Wireless Router
I am trying to set up a wireless network. Trendnet TEW-652BRP router. Book says to go to 192.168.10.1? I get INternet Explorer cannot display them webpage. i went to run>cmd ping 192.168.10.1 Request...
open up command prompt (run--> cmd) and type in "ipconfig" (without quotes). Look for the folowing: Default Gateway: 192.168.something.something Open up internet explorer and go to that 192.168.something.something instead of going to 192.168.10.1
You should be able to finish configuration from here. Also, you have to be connected to the router, either wirelessly or with a cable in order to access the settings, double check your connection.
Good luck
Dec 28, 2009 | Trendware TEW-652BRP Router
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Unable to find a local connection icon in my HP computer--
check for the ethernet cable attached to this computer. try doing the loop back test
start->run->type cmd-> type the command ping 127.0.0.1
If u get 4 packets sent recived 4 then everything is fine u have some browser or OS issues else if u see 4 packets sent and lost some then prb with the network card or the ethernet cable.
Jun 17, 2009 | HP-HSC HP-IB Interface (E2071D) Network...
I get kicked due to high ping what should i do?
When choosing a server try to sort the list by ping rate and go with the lowest ping you can that is offering the map and amount of players you are looking for. If you frequently get disconnected or see connection_error on your screen while playing it could be a problem with your actual internet connection dropping packets. To test that you will need to ping a well known server like google or microsoft and see what ping times you get and if any packets are lost. This can by done by clicking start -> run and typing cmd then pressing ok. In the dos box that pops up type ping -n 20 www.google.com and press enter. Significant packet loss and high ping times could mean your connection is saturated from other downloads/uploads, there is some bad cabling or network hardware somewhere, or your ISP is having some problems. If you are connected to a router or other network equipment and assuming you have a high speed connection try connecting directly to the modem provided to you and see if that helps. If the problem continues you will need to contact your internet provider for additional troubleshooting.
Mar 17, 2009 | Electronic Arts Counter-Strike: Source for...
Linksys befw11s4 wireless b v.4 ping problems
have him do a traceroute to try to isolate where the packets start to drop
Sep 29, 2008 | Computers & Internet
IBM thinkpad T21
Bad cable, bad network configuration or bad motherboard, in that order.
Try manual settings for the wired connection, do a repair and see what the comment is.
good luck
Dec 23, 2007 | IBM ThinkPad T21 Notebook
Dell Latitude D600 Notebook Logo
73 people viewed this question
Clive
Clive
Alun Cox
