Question about Kenmore 24 in. 17532 Built-in Dishwasher
Fills with water, hums, does not spray water, Kenmore model 17532
  • 224 Answers
The motor is blocked. Try taking off the kick plate and when you hear the hum, move the impeller blades with a screw driver to jump it into gear. If you can't get it going, you'll need a new motor, but this is a pain to install.
Posted on Jul 12, 2009
My kenmore washing machine series 80 model stuck in soak cycle and will not pass to rinse cycle
This is usualy caused by the cold water not entering the machine. If you hear a humming noise it means the fill valve is operating but no water is present. Has some one turned the cold water off? Failing that the fill valve may be faulty and need replacing.
Oct 03, 2014 | Kenmore Washing Machines
Manual for Kenmore quiet guard1 dishwasher model#58716169400
Here is a dishwasher manual search engine, they will find the Kenmore dishwasher user manual within minutes. Just send them a search request for your model.
Aug 12, 2012 | Kenmore 24 in. 17532 Built-in Dishwasher
Mold growing from inner vent
Spray vent area with 1/4 cup bleach mixed with 1 quart water and run cycle without dishes in it.
May 06, 2011 | Kenmore 24 in. 17532 Built-in Dishwasher
Water fills in kenmore elite 16263 but wont wash. It just hums when it supposed to be washing.
HI- The motor is locked up. A seal between the motor and the impeller has worn out causing the shaft bearing to freeze up. Motors are about 100$. Labor should be about the same. Not a defect, just a little shaft seal that only lasts about 4-6 yrs. Let me know if this info helps- ED
Mar 02, 2010 | Kenmore 24 in. 17532 Built-in Dishwasher
My kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Jan 14, 2010 | Kenmore Dishwashers
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 17532 Built-in Dishwasher Logo
206 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
