Question about Panasonic Toughbook CF-73 Notebook
Standard RAM Failure after extended RAM replacement
I just replaced my exteneded 1GB RAM with a 2GB RAM and now the start up error says standard RAM failure
  • 390 Answers
Hi
there are two hings to be noted here
1. the toughbook supports DDR2 SDRAM check to see if u have the right thing installed
2. the toughbook is expandable to 1536MB roughly1.5GB while you have put in 2GB and the possibilities are it is thus rejecting
try taking off the expanded ram chips and if it works then try expanding to 1.5GB (meaning add only one 512 RAM Chip) first and then check
cheers
pls rate if this was any help
Posted on Jul 12, 2009
    Problem Solver:
  • 10 Answers
Sometimes only certain types of RAM cards work with a computer. Check the old card to see what type it is. (Look for the letters "CMOS" or "EDO".) Make sure the new card is the same type as the old one. If not, put the old one back in and find the proper type of card.
Where is the memory slots for the Panasonic CF-T8. I know about the one on the back where it the other slot?
According to Panasonic's Toughbook CFT8
owners manual there is only one slot where
you can add extra RAM. The other memory
is "non-removable" and probably soldered
directly to the motherboard.
I double checked on the Kingston RAM Website:
Bank Schema: 1GB Standard:
[1GB] (Non-Removable)
or
3GB Standard:
or
2GB Standard:
[2GB] (Non-Removable)
or
3GB Standard:
Sorry to disappoint you but that is how they
made the CFT8 Toughbook.
If it is any consolation, the CFC1 and CFC2 both have
two (2) slots on the underside of the unit. Not the CFT8.
Good Luck,
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 17, 2014 | Panasonic Toughbook Cf-t8 Win7 Core2 Duo...
Repeatedly long beeps
If you upreage the RAM to 2Gb by inserting a 2nd 1Gb memory module then the 2nd RAM maybe faulty or incompatible.
If you insert a 2gb memory module to replace the 1Gb memory module then it maybe faulty or incompatible.
Try using the same make and RAM speed as the original RAM module.
Dec 29, 2012 | Biostar G31-M7 TE Motherboard
Here's my issue. Ok i have 2 ram slots. When I have 2 1GB ram cards in the slots the computer registers 2GB ram. When I put in 2GB card and 1GB card, it only registers 2GB RAM. No idea why. I bought...
the issue may be the ram is not the same like a PC100 will not work with a PC300 ram card but if you have the same like a 2GB DDR2 and a 1GB DDR2 it will work unless your computer can only see 2GB of ram then i cannot help you
Jan 02, 2011 | Computers & Internet
Just installed 2 2GB cards (Corsair VS2GB800D2) to replace the 1 1GB card in my emachines EL1200 series. Computer will not boot. replaced the old card and it booted right up.
Will it boot with only ONE of the 2GB memory-sticks installed?
Will it boot with ONE of the 2GB memory-sticks AND one of the 1GB memory-sticks?
Look closely at the 1GB memory-sticks.
Does the label show 'DDR266' or 'DDR333' or 'DDR400' or 'PC2100' or 'PC2700' or 'PC3200' ?
Do the 2GB memory-sticks have _identical_ information?
It's definitely _not_ acceptable to have "slower" RAM (smaller numbers) in the new RAM,
but it _might_ be acceptable to have "faster" RAM (larger numbers).
Nov 12, 2010 | E-Machines eMachines Desktop PC
Acer Aspire 5610 RAM upgrade issue. Sorry, it's long-winded. I included everything. lol I'm trying to upgrade from 1GB (two 512mb modules), to 2GB (two 1GB modules). The max for this machine is supposed to...
first refer to the motherboard's manual and see the max. RAM support.... then go to system properties | advanced tab | start up and recovery | go to settings under system failure....uncheck automatically restart
then when the blue screen appears....note down the error message and error code.... post the message and code to me...
this might ease your problem a little bit....
Jan 11, 2010 | Acer Aspire 5610 Notebook
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
Hi does anybody know what make and model of 1GB ram can I use for
buy a good named brand ram chip and you will be fine
  • Maximum Memory: 2048MB
  • Slots: 2 (2 banks of 1)
  • Standard Memory: 512 or 1024MB removable
  • Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
    *Not to exceed manufacturer supported memory.
    Dec 18, 2008 | HP Pavilion dv6000z Notebook
    RAM
    download and install: http://www.filehippo.com/download_ccleaner/
    this will allow you to delete the things that startup in the task bar. Windows will load faster, and you can open just the programs you want. This will not delete the program just remove them from automaticly starting up. RAM always helps. 1GB is the standard for XP to run very smoothly 2GB is the best
    Aug 18, 2008 | Toshiba Satellite A135-S4527 Notebook
    EXTENDING EXIST 2Gb RAM to 4Gb
    hai ,frist u go to
    start--my computer(right click it)---manage---disk management---
    see your new hard disk & right click and shirnk volume
    Jul 13, 2008 | Toshiba Satellite P205-S6287 Notebook PC
    Acer L100 memory upgrade
    you can open it up and see, take out the ram to see what kind it is
    Dec 24, 2007 | Acer Aspire L100 PC Desktop
    Panasonic Toughbook CF-73 Notebook Logo
    556 people viewed this question
    Top Panasonic Computers & Internet Experts
    Oloyede Monsuru
    micky dee
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
