Tv no picture makes sound like cricket three times, green light on then shuts down and lamp light comes on, most of the time but sometimes just shuts down completely
  • 50 Answers
Lamp light flashing? possibly going out and needs replacing. google search the model number and lamp replacement, you might get lucky and find a replacement. around $250.
Posted on Aug 07, 2009
My RCA model # HD52W59, power on and shuts down without coming on. Green come on then shuts down. No picture or sound.
The set is in shutdown because of a problem inside, this model has the three strikes and your out, it will try three times to come on and then latch down. It likely needs a shop repair of some kind.
Aug 27, 2012 | Televison & Video
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Intermittant shut down with blinking green light on Sony TV 55"
Hi,Make sure you get the Original Philips lamps since they last 6000-8000 hrs 2-4 yrs,way better then Osram which last 4000-5000 hrs 1 - 1/2 yrs.
Oct 01, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Apr 22, 2009 | Televison & Video
Lamp light blinks 3 times shuts down
The CLS problem. Im thinking that at least you made a visual inspection of the power suply and the capacitors around it. Then if everything normal in the area then the microdisplay (inside the ligth engine) can be damaged. (when the tv is working normally the microdisplay sends a pulse to turn on ballast and lamp finally.
The sweetkyman: when the fan is bad th tv shuts down imm. (if you unplug the fan when the tv is working normal the computer detects the overcurrent system works and shuts down the set) when a fan is all dirty and tons of dust on it the tv tends to work but after some hours the tv shuts down.
Dec 20, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Sony Grand Wega KDF-60XS955 Picture comes on and then goes off.
You have a bad lamp. Sometimes when the lamp gets old, it doesn't fail and open like they usually do. Instead, the reflector gets cloudy, and instead of reflecting the light, it converts it into heat. As the lamp heats up, it draws more power, eventually to the point where the TV senses it drawing too much power and shuts down, going into a reset cycle. replace the lamp and use an original Sony lamp, as the aftermarket lamps are known trouble makers. Be sure to rate this solution. Thanks!
Dec 13, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Samsung 46" DLP
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Nov 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
